[GRASS-QA] GRASS QA: martinl |init2d.c interpf.h main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Mar 19 13:29:04 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/rst/interp_float/init2d.c
          Function
IL_init_func_2d(Begins at: 93, Ends at:112)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |      15 |   *** |      MONSTER |        15 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      20 |       |           OK |        20 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
IL_init_params_2d(Begins at: 19, Ends at:91)
ParamNBR:     |      44 |   *** |      MONSTER |        44 |
LOC:          |      73 |     * |      WARNING |        73 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/rst/interp_float/interpf.h
          Class
fcell_triple(Begins at: 12, Ends at:18)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
interp_params(Begins at: 38, Ends at:72)
|NEW Metrics |      1 |      0 |      0 |      7 |      0 |     21 |
|OLD Metrics |      1 |      0 |      0 |      7 |      0 |     21 |
Clone analysis:
          File :grass/trunk/vector/v.surf.rst/main.c
          Function
clean_fatal_error(Begins at: 848, Ends at:875)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
main(Begins at: 129, Ends at:802)
Complexity:   |      99 |   *** |      MONSTER |        99 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     291 |   *** |      MONSTER |       291 |
LOC:          |     674 |   *** |      MONSTER |       674 |
print_tree(Begins at: 806, Ends at:844)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      39 |       |           OK |        39 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Mar 19 12:37:39 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
