[GRASS-QA] GRASS QA: mmetz |build_nat.c poly.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Mar 23 06:08:12 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/build_nat.c
          Function
Vect_attach_centroids(Begins at: 332, Ends at:413)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      82 |     * |      WARNING |        82 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Vect_attach_isle(Begins at: 261, Ends at:288)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_attach_isles(Begins at: 298, Ends at:322)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Vect_build_line_area(Begins at: 40, Ends at:118)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      79 |     * |      WARNING |        79 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Vect_build_nat(Begins at: 425, Ends at:677)
Complexity:   |      42 |   *** |      MONSTER |        42 |
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     253 |   *** |      MONSTER |       253 |
Conclusion:   | this function is a       MONSTER           |
Vect_isle_find_area(Begins at: 129, Ends at:251)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |     123 |    ** | BABY-MONSTER |       123 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/Vlib/poly.c
          Class
Slink(Begins at: 28, Ends at:32)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
V__within(Begins at: 111, Ends at:122)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      12 |       |           OK |        12 |
 at least 1 values are close to an outlier please consider revising code!
Vect__divide_and_conquer(Begins at: 266, Ends at:304)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      39 |       |           OK |        39 |
Vect__intersect_line_with_poly(Begins at: 140, Ends at:167)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       2 |       |           OK |         2 |
Vect_find_poly_centroid(Begins at: 329, Ends at:366)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      38 |       |           OK |        38 |
Vect_get_point_in_area(Begins at: 60, Ends at:98)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
 at least 3 values are close to an outlier please consider revising code!
Vect_get_point_in_poly(Begins at: 180, Ends at:242)
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      63 |     * |      WARNING |        63 |
 at least 4 values are close to an outlier please consider revising code!
Vect_get_point_in_poly_isl(Begins at: 423, Ends at:547)
Complexity:   |      26 |   *** |      MONSTER |        26 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |     125 |    ** | BABY-MONSTER |       125 |
Vect_point_in_area_outer_ring(Begins at: 694, Ends at:747)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      54 |     * |      WARNING |        54 |
Vect_point_in_island(Begins at: 760, Ends at:805)
LOC:          |      46 |     * |      WARNING |        46 |
Vect_point_in_poly(Begins at: 665, Ends at:681)
LOC:          |      17 |       |           OK |        17 |
comp_double(Begins at: 100, Ends at:109)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
destroy_links(Begins at: 306, Ends at:317)
ParamNBR:     |       1 |       |           OK |         1 |
metrics are OK
segments_x_ray(Begins at: 554, Ends at:653)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |     100 |    ** | BABY-MONSTER |       100 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Mar 23 05:17:34 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
