[GRASS-QA] GRASS QA: hamish |spawn.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue May 12 07:20:49 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/gis/spawn.c
          Class
binding(Begins at: 188, Ends at:192)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
redirect(Begins at: 168, Ends at:174)
          Class
signal(Begins at: 176, Ends at:186)
          Function
G_spawn(Begins at: 89, Ends at:164)
              |          New Metrics           |Old Metrics|
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      24 |    ** | BABY-MONSTER |        24 |
LOC:          |      76 |     * |      WARNING |        76 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
G_spawn_ex(Begins at: 642, Ends at:653)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      12 |       |           OK |        12 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_vspawn_ex(Begins at: 623, Ends at:630)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
begin_spawn(Begins at: 453, Ends at:461)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
do_bindings(Begins at: 214, Ends at:222)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
do_bindings(Begins at: 379, Ends at:391)
Complexity:   |       2 |     * |      WARNING |         2 |
ParamNBR:     |       2 |       |           OK |         3 |
CalledNBR:    |       5 |     * |      WARNING |         1 |
LOC:          |      13 |       |           OK |         9 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
do_redirects(Begins at: 342, Ends at:377)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      36 |     * |      WARNING |        36 |
 at least 4 values are close to an outlier please consider revising code!
do_signals(Begins at: 281, Ends at:340)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      17 |    ** | BABY-MONSTER |        17 |
LOC:          |      60 |     * |      WARNING |        60 |
do_spawn(Begins at: 393, Ends at:449)
Complexity:   |      10 |    ** | BABY-MONSTER |        10 |
CalledNBR:    |      23 |     * |      WARNING |        23 |
LOC:          |      57 |     * |      WARNING |        57 |
parse_arglist(Begins at: 539, Ends at:611)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      73 |     * |      WARNING |        73 |
parse_argvec(Begins at: 465, Ends at:537)
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |      17 |       |           OK |        17 |
LOC:          |      73 |       |           OK |        73 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue May 12 07:35:54 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
