[GRASS-QA] GRASS QA: hamish |dbmscap.c start.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Nov 5 14:02:47 EST 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c
          Function
add_entry(Begins at: 191, Ends at:219)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      29 |       |           OK |        29 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
db_copy_dbmscap_entry(Begins at: 67, Ends at:72)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
db_dbmscap_filename(Begins at: 45, Ends at:48)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_free_dbmscap(Begins at: 227, Ends at:235)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
db_has_dbms(Begins at: 56, Ends at:59)
metrics are OK
db_read_dbmscap(Begins at: 87, Ends at:189)
CalledNBR:    |      29 |    ** | BABY-MONSTER |        29 |
LOC:          |     103 |    ** | BABY-MONSTER |       103 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
dbmscap_filename(Begins at: 20, Ends at:37)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/lib/db/dbmi_client/start.c
          Function
db_start_driver(Begins at: 29, Ends at:329)
Complexity:   |      29 |   *** |      MONSTER |        29 |
CalledNBR:    |      87 |   *** |      MONSTER |        87 |
LOC:          |     301 |   *** |      MONSTER |       301 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Nov 05 14:02:47 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
