[GRASS-QA] GRASS QA: martinl |select.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Nov 5 17:06:58 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/db/dbmi_client/select.c
          Function
cmp(Begins at: 21, Ends at:31)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
cmpcat(Begins at: 33, Ends at:43)
metrics are OK
cmpcatkey(Begins at: 45, Ends at:55)
metrics are OK
cmpvaluedouble(Begins at: 70, Ends at:81)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
cmpvalueint(Begins at: 57, Ends at:68)
metrics are OK
cmpvaluestring(Begins at: 83, Ends at:89)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
db_CatValArray_get_value(Begins at: 418, Ends at:432)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
db_CatValArray_get_value_double(Begins at: 470, Ends at:486)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      17 |       |           OK |        17 |
db_CatValArray_get_value_int(Begins at: 444, Ends at:458)
db_CatValArray_sort(Begins at: 369, Ends at:372)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_CatValArray_sort_by_value(Begins at: 382, Ends at:406)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      25 |       |           OK |        25 |
db_select_CatValArray(Begins at: 247, Ends at:363)
Complexity:   |      17 |    ** | BABY-MONSTER |        17 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      45 |   *** |      MONSTER |        45 |
LOC:          |     117 |    ** | BABY-MONSTER |       117 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
db_select_int(Begins at: 103, Ends at:180)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      78 |     * |      WARNING |        78 |
Conclusion:   | this function is a  BABY-MONSTER           |
db_select_value(Begins at: 195, Ends at:233)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      39 |       |           OK |        39 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Nov 05 17:06:58 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
