[GRASS-QA] GRASS QA: martinl |cursor.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Nov 5 19:41:26 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/db/dbmi_base/cursor.c
          Function
db_alloc_cursor_column_flags(Begins at: 254, Ends at:266)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
db_alloc_cursor_table(Begins at: 26, Ends at:32)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
db_free_cursor(Begins at: 40, Ends at:47)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
db_free_cursor_column_flags(Begins at: 274, Ends at:279)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
db_get_cursor_number_of_columns(Begins at: 366, Ends at:374)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
db_get_cursor_table(Begins at: 55, Ends at:58)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_get_cursor_token(Begins at: 77, Ends at:80)
metrics are OK
db_init_cursor(Begins at: 10, Ends at:18)
metrics are OK
db_set_cursor_column_flag(Begins at: 331, Ends at:335)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
db_set_cursor_column_for_update(Begins at: 287, Ends at:290)
metrics are OK
db_set_cursor_mode(Begins at: 165, Ends at:168)
metrics are OK
db_set_cursor_mode_insensitive(Begins at: 209, Ends at:212)
metrics are OK
db_set_cursor_mode_scroll(Begins at: 176, Ends at:179)
metrics are OK
db_set_cursor_table(Begins at: 66, Ends at:69)
metrics are OK
db_set_cursor_token(Begins at: 88, Ends at:91)
metrics are OK
db_set_cursor_type_insert(Begins at: 121, Ends at:124)
metrics are OK
db_set_cursor_type_readonly(Begins at: 99, Ends at:102)
metrics are OK
db_set_cursor_type_update(Begins at: 110, Ends at:113)
metrics are OK
db_test_cursor_any_column_flag(Begins at: 383, Ends at:392)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
db_test_cursor_any_column_for_update(Begins at: 320, Ends at:323)
metrics are OK
db_test_cursor_column_flag(Begins at: 355, Ends at:358)
metrics are OK
db_test_cursor_column_for_update(Begins at: 309, Ends at:312)
metrics are OK
db_test_cursor_mode_insensitive(Begins at: 243, Ends at:246)
metrics are OK
db_test_cursor_mode_scroll(Begins at: 231, Ends at:234)
metrics are OK
db_test_cursor_type_fetch(Begins at: 132, Ends at:135)
metrics are OK
db_test_cursor_type_insert(Begins at: 154, Ends at:157)
metrics are OK
db_test_cursor_type_update(Begins at: 143, Ends at:146)
metrics are OK
db_unset_cursor_column_flag(Begins at: 343, Ends at:347)
metrics are OK
db_unset_cursor_column_for_update(Begins at: 298, Ends at:301)
metrics are OK
db_unset_cursor_mode(Begins at: 198, Ends at:201)
metrics are OK
db_unset_cursor_mode_insensitive(Begins at: 220, Ends at:223)
metrics are OK
db_unset_cursor_mode_scroll(Begins at: 187, Ends at:190)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Nov 05 19:41:26 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
