[GRASS-QA] GRASS QA: neteler |copy.c main.c main.c main.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Nov 19 11:31:54 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/db/base/copy.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/display/d.grid/main.c
          File :grass/branches/develbranch_6/display/d.thematic.area/main.c
          File :grass/branches/develbranch_6/doc/vector/v.example/main.c
          File :grass/branches/develbranch_6/general/g.mapset/main.c
          File :grass/branches/develbranch_6/general/g.proj/datumtrans.c
          File :grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/main.c
          File :grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/where.c
          File :grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c
          File :grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/where.c
          File :grass/branches/develbranch_6/imagery/i.points/main.c
          File :grass/branches/develbranch_6/imagery/i.vpoints/drawvect.c
          File :grass/branches/develbranch_6/imagery/i.vpoints/main.c
          File :grass/branches/develbranch_6/imagery/i.vpoints/where.c
          File :grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
          File :grass/branches/develbranch_6/lib/db/dbmi_client/start.c
          File :grass/branches/develbranch_6/lib/db/dbmi_driver/driver.c
          File :grass/branches/develbranch_6/lib/gis/cats.c
          File :grass/branches/develbranch_6/lib/gis/env.c
          File :grass/branches/develbranch_6/lib/gis/error.c
          File :grass/branches/develbranch_6/lib/gis/G.h
          File :grass/branches/develbranch_6/lib/gis/gdal.c
          File :grass/branches/develbranch_6/lib/gis/get_row.c
          File :grass/branches/develbranch_6/lib/gis/get_window.c
          File :grass/branches/develbranch_6/lib/gis/gisinit.c
          File :grass/branches/develbranch_6/lib/gpde/N_arrays_io.c
          File :grass/branches/develbranch_6/lib/ogsf/gsd_legend.c
          File :grass/branches/develbranch_6/lib/proj/convert.c
          File :grass/branches/develbranch_6/lib/sites/sites.c
          File :grass/branches/develbranch_6/lib/vector/diglib/plus_struct.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/area.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/break_lines.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/bridges.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/buffer.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/build.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/dangles.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/remove_duplicates.c
          File :grass/branches/develbranch_6/lib/vector/Vlib/snap.c
          File :grass/branches/develbranch_6/raster/r.gwflow/main.c
          File :grass/branches/develbranch_6/raster/r.le/r.le.patch/patch.c
          File :grass/branches/develbranch_6/raster/r.out.arc/main.c
          File :grass/branches/develbranch_6/raster/r.out.gdal/main.c
          File :grass/branches/develbranch_6/raster/r.to.vect/main.c
          File :grass/branches/develbranch_6/vector/v.clean/proto.h
          File :grass/branches/develbranch_6/vector/v.distance/main.c
          File :grass/branches/develbranch_6/vector/v.edit/a2b.c
          File :grass/branches/develbranch_6/vector/v.edit/args.c
          File :grass/branches/develbranch_6/vector/v.label.sa/main.c
____________________________________________
Threshold grass key metrics values at Thu Nov 19 11:31:54 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
