[GRASS-QA] GRASS QA: hamish |in.c points.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Sep 20 01:03:31 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.in.ascii/in.c
          Function
main(Begins at: 30, Ends at:563)
              |          New Metrics           |Old Metrics|
Complexity:   |      69 |   *** |      MONSTER |        69 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     206 |   *** |      MONSTER |       206 |
LOC:          |     534 |   *** |      MONSTER |       534 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/vector/v.in.ascii/points.c
          Function
is_double(Begins at: 29, Ends at:40)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      12 |       |           OK |        12 |
Conclusion:   | this function is a            OK           |
metrics are OK
is_int(Begins at: 13, Ends at:24)
metrics are OK
points_analyse(Begins at: 54, Ends at:268)
Complexity:   |      34 |   *** |      MONSTER |        34 |
ParamNBR:     |      13 |   *** |      MONSTER |        13 |
CalledNBR:    |      55 |   *** |      MONSTER |        55 |
LOC:          |     215 |   *** |      MONSTER |       215 |
points_to_bin(Begins at: 279, Ends at:417)
Complexity:   |      17 |    ** | BABY-MONSTER |        17 |
ParamNBR:     |      14 |   *** |      MONSTER |        14 |
CalledNBR:    |      58 |   *** |      MONSTER |        58 |
LOC:          |     139 |    ** | BABY-MONSTER |       139 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sun Sep 20 01:03:31 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
