[GRASS-QA] GRASS QA: mmetz |ami_stream.h | no clones | 0 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Aug 10 08:56:26 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42806
ANALYSIS
your changes to files/class/methods/functions :
          File :/include/iostream/ami_stream.h
          Class
AMI_STREAM(Begins at: 150, Ends at:201)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      2 |      0 |      0 |     14 |      1 |     91 |
|OLD Metrics |        |        |        |        |        |        |
          Class
AMI_STREAM<T>(Begins at: -9999, Ends at:-9999)
|NEW Metrics |      1 |      0 |     34 |     38 |      0 |      6 |
          Method
stream_len(Begins at: 379, Ends at:430)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |           |
ParamNBR:     |       1 |       |           OK |           |
CalledNBR:    |      20 |     * |      WARNING |           |
LOC:          |      52 |       |           OK |           |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
new_substream(Begins at: 316, Ends at:372)
Complexity:   |       5 |       |           OK |           |
ParamNBR:     |       4 |     * |      WARNING |           |
CalledNBR:    |       5 |       |           OK |           |
LOC:          |      57 |       |           OK |           |
          Class
UntypedStream(Begins at: 119, Ends at:147)
|NEW Metrics |      1 |      0 |      1 |      1 |      0 |      0 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Aug 10 08:56:25 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        42 |        66 |
LOC:                  |        66 |       149 |       233 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
