[GRASS-QA] GRASS QA: glynn |rasterdefs.h main.c init.c closecell.c
...| 3 clones | 8 monsters |15 warnings
soccerlab.info at gmail.com
Tue Aug 10 11:43:23 EDT 2010
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 42876
ANALYSIS
your changes to files/class/methods/functions :
File :/include/rasterdefs.h
The system don't find class, method and function
in this file during analysis!
File :/raster/r.proj/main.c
Function
main(Begins at: 78, Ends at:516)
| New Metrics |Old Metrics|
Complexity: | 36 | *** | MONSTER | 36 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 192 | *** | MONSTER | 192 |
LOC: | 439 | *** | MONSTER | 439 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/raster/r.random.cells/init.c
Function
Init(Begins at: 15, Ends at:111)
Complexity: | 18 | * | WARNING | 18 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 34 | * | WARNING | 34 |
LOC: | 97 | * | WARNING | 97 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :/lib/raster/closecell.c
Function
close_new(Begins at: 334, Ends at:467)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 44 | ** | BABY-MONSTER | 44 |
LOC: | 134 | * | WARNING | 134 |
Conclusion: | this function is a BABY-MONSTER |
close_new_gdal(Begins at: 255, Ends at:332)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 30 | * | WARNING | 30 |
LOC: | 78 | * | WARNING | 78 |
Clone analysis:
File :/imagery/i.ifft/main.c
Function
main(Begins at: 54, Ends at:230)
Complexity: | 15 | * | WARNING | 15 |
CalledNBR: | 72 | *** | MONSTER | 72 |
LOC: | 177 | ** | BABY-MONSTER | 177 |
Clone analysis:
File :/raster/simwe/simlib/output.c
Function
output_et(Begins at: 582, Ends at:723)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 33 | * | WARNING | 33 |
LOC: | 142 | * | WARNING | 142 |
output_data(Begins at: 15, Ends at:579)
Complexity: | 72 | *** | MONSTER | 72 |
CalledNBR: | 173 | *** | MONSTER | 173 |
LOC: | 565 | *** | MONSTER | 565 |
Clone analysis:
File :/imagery/i.atcorr/main.cpp
Class
IntPair(Begins at: 218, Ends at:232)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 5 | 2 | 0 | 1 |
|OLD Metrics | | | | | | |
Class
Options(Begins at: 48, Ends at:67)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Position(Begins at: 187, Ends at:193)
|NEW Metrics | 1 | 0 | 2 | 2 | 0 | 1 |
Class
ScaleRange(Begins at: 69, Ends at:73)
Class
TICache(Begins at: 129, Ends at:161)
|NEW Metrics | 1 | 0 | 8 | 4 | 0 | 2 |
Class
TIMap(Begins at: 173, Ends at:215)
|NEW Metrics | 1 | 0 | 8 | 7 | 0 | 4 |
Function
main(Begins at: 558, Ends at:647)
LOC: | 90 | * | WARNING | 90 |
adjust_region(Begins at: 95, Ends at:102)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 8 | | OK | 8 |
Conclusion: | this function is a OK |
metrics are OK
copy_colors(Begins at: 412, Ends at:418)
CalledNBR: | 3 | | OK | 3 |
LOC: | 7 | | OK | 7 |
metrics are OK
Clone analysis:
File :/display/d.rast.num/main.c
Function
main(Begins at: 50, Ends at:246)
Complexity: | 16 | * | WARNING | 16 |
CalledNBR: | 62 | ** | BABY-MONSTER | 62 |
LOC: | 197 | ** | BABY-MONSTER | 197 |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/display/d.rast.num/main.c clones of main are:
/var/project-manager/grass/grassSVN/grass/trunk/display/d.rast.num/main.c main
File :/lib/rst/interp_float/resout2d.c
Function
IL_resample_output_2d(Begins at: 45, Ends at:462)
Complexity: | 52 | *** | MONSTER | 52 |
ParamNBR: | 18 | *** | MONSTER | 18 |
CalledNBR: | 129 | *** | MONSTER | 129 |
LOC: | 418 | *** | MONSTER | 418 |
Clone analysis:
File :/raster/r.coin/main.c
Function
main(Begins at: 46, Ends at:137)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 37 | * | WARNING | 37 |
LOC: | 92 | * | WARNING | 92 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :/imagery/i.rectify/write.c
Function
write_map(Begins at: 39, Ends at:62)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 24 | | OK | 24 |
metrics are OK
Clone analysis:
File :/lib/rst/interp_float/output2d.c
Function
IL_output_2d(Begins at: 49, Ends at:556)
Complexity: | 57 | *** | MONSTER | 57 |
CalledNBR: | 142 | *** | MONSTER | 142 |
LOC: | 508 | *** | MONSTER | 508 |
Clone analysis:
File :/raster/r.resamp.interp/main.c
Function
main(Begins at: 56, Ends at:309)
CalledNBR: | 109 | *** | MONSTER | 109 |
LOC: | 254 | *** | MONSTER | 254 |
Clone analysis:
File :/raster/r.horizon/main.c
Function
main(Begins at: 160, Ends at:504)
Complexity: | 32 | *** | MONSTER | 32 |
CalledNBR: | 112 | *** | MONSTER | 112 |
LOC: | 345 | *** | MONSTER | 345 |
Clone analysis:
File :/raster/r.flow/io.c
Function
write_density_file(Begins at: 194, Ends at:241)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 48 | | OK | 48 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
File :/lib/raster/set_window.c
Function
Rast__init_window(Begins at: 24, Ends at:36)
Complexity: | 2 | | OK | 2 |
LOC: | 13 | | OK | 13 |
metrics are OK
Rast_set_window(Begins at: 43, Ends at:59)
CalledNBR: | 6 | | OK | 6 |
LOC: | 17 | | OK | 17 |
metrics are OK
check_write_window(Begins at: 159, Ends at:170)
LOC: | 12 | | OK | 12 |
metrics are OK
Rast_set_output_window(Begins at: 66, Ends at:78)
CalledNBR: | 4 | | OK | 4 |
metrics are OK
update_window_mappings(Begins at: 100, Ends at:157)
CalledNBR: | 7 | | OK | 7 |
LOC: | 58 | | OK | 58 |
Clone analysis:
File :/raster/r.resamp.filter/main.c
Class
filter(Begins at: 147, Ends at:151)
|NEW Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
Class
filter_type(Begins at: 93, Ends at:97)
Function
filter(Begins at: 313, Ends at:364)
CalledNBR: | 10 | | OK | 10 |
LOC: | 52 | | OK | 52 |
metrics are OK
main(Begins at: 366, Ends at:559)
CalledNBR: | 82 | *** | MONSTER | 82 |
LOC: | 194 | ** | BABY-MONSTER | 194 |
Clone analysis:
File :/imagery/i.rectify/rectify.c
Function
rectify(Begins at: 14, Ends at:108)
Complexity: | 8 | | OK | 8 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 26 | * | WARNING | 26 |
LOC: | 95 | * | WARNING | 95 |
Clone analysis:
File :/lib/raster/alloc_cell.c
Function
Rast_allocate_f_output_buf(Begins at: 193, Ends at:196)
LOC: | 4 | | OK | 4 |
metrics are OK
Rast_allocate_null_output_buf(Begins at: 203, Ends at:206)
metrics are OK
Rast__null_bitstream_size(Begins at: 148, Ends at:155)
metrics are OK
Rast_allocate_input_buf(Begins at: 157, Ends at:160)
metrics are OK
Rast_allocate_d_input_buf(Begins at: 172, Ends at:175)
metrics are OK
Rast_allocate_f_input_buf(Begins at: 167, Ends at:170)
metrics are OK
Rast_allocate_d_output_buf(Begins at: 198, Ends at:201)
metrics are OK
Rast_allocate_null_input_buf(Begins at: 177, Ends at:180)
metrics are OK
Rast_allocate_c_input_buf(Begins at: 162, Ends at:165)
metrics are OK
Rast_allocate_c_output_buf(Begins at: 188, Ends at:191)
metrics are OK
Rast_allocate_output_buf(Begins at: 183, Ends at:186)
metrics are OK
Clone analysis:
File :/lib/raster/get_row.c
Function
get_map_row_nomask(Begins at: 574, Ends at:604)
LOC: | 31 | | OK | 31 |
Clone analysis:
File :/lib/raster/zero_cell.c
Function
Rast_zero_input_buf(Begins at: 33, Ends at:36)
metrics are OK
Rast_zero_buf(Begins at: 28, Ends at:31)
metrics are OK
Rast_zero_output_buf(Begins at: 38, Ends at:41)
metrics are OK
Clone analysis:
File :/raster/r.resamp.stats/main.c
Function
resamp_weighted(Begins at: 153, Ends at:234)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 82 | * | WARNING | 82 |
resamp_unweighted(Begins at: 86, Ends at:151)
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 66 | | OK | 66 |
main(Begins at: 236, Ends at:377)
CalledNBR: | 65 | ** | BABY-MONSTER | 65 |
Clone analysis:
This file has 2 potentially cloned functions:
resamp_unweighted
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.stats/main.c clones of resamp_weighted are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.stats/main.c resamp_weighted
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.stats/main.c clones of resamp_unweighted are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.resamp.stats/main.c resamp_unweighted
File :/raster/r.proj/readcell.c
Function
readcell(Begins at: 18, Ends at:107)
CalledNBR: | 29 | * | WARNING | 29 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Aug 10 11:43:22 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
