[GRASS-QA] GRASS QA: hamish |rsunlib.c | no clones | 0 monsters |6 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Aug 10 14:14:54 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 42938
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.sun/rsunlib.c
          Function
setHorizonInterval(Begins at: 99, Ends at:102)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
brad(Begins at: 455, Ends at:499)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      45 |       |           OK |        45 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
com_par_const(Begins at: 139, Ends at:180)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      42 |       |           OK |        42 |
com_par(Begins at: 186, Ends at:291)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |     106 |     * |      WARNING |       106 |
 at least 3 values are close to an outlier please consider revising code!
drad(Begins at: 548, Ends at:613)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |      66 |     * |      WARNING |        66 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
brad_angle_loss(Begins at: 501, Ends at:544)
LOC:          |      44 |       |           OK |        44 |
drad_angle_loss(Begins at: 617, Ends at:712)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      96 |     * |      WARNING |        96 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Aug 10 14:14:54 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
