[GRASS-QA] GRASS QA: wegmann |main.c frag.c helpers.c parse.c ...|
	no clones | 1 monsters |7 warnings
    soccerlab.info at gmail.com
    Tue Aug 10 16:30:09 EDT 2010
Hello wegmann,
here's a report on your recent grass-SVN change for the revision : 42990
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.pi/r.pi.import/main.c
          Function
main(Begins at: 9, Ends at:253)
              |          New Metrics           |Old Metrics|
Complexity:   |      13 |     * |      WARNING |        13 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      76 |   *** |      MONSTER |        76 |
LOC:          |     245 |   *** |      MONSTER |       245 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.pi/r.pi.import/frag.c
          Function
getNeighbors(Begins at: 13, Ends at:63)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      51 |       |           OK |        51 |
Conclusion:   | this function is a  BABY-MONSTER           |
writeFrag(Begins at: 65, Ends at:154)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      90 |     * |      WARNING |        90 |
writeFragments(Begins at: 156, Ends at:179)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      24 |       |           OK |        24 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :/raster/r.pi/r.pi.import/helpers.c
          Function
Random(Begins at: 8, Ends at:13)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
Randomf(Begins at: 15, Ends at:18)
ParamNBR:     |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Round(Begins at: 3, Ends at:6)
metrics are OK
print_array(Begins at: 58, Ends at:66)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
print_buffer(Begins at: 20, Ends at:43)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
print_d_buffer(Begins at: 45, Ends at:56)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      12 |       |           OK |        12 |
print_fragments(Begins at: 68, Ends at:81)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
print_map(Begins at: 83, Ends at:94)
metrics are OK
Clone analysis:
          File :/raster/r.pi/r.pi.import/parse.c
          Function
parse(Begins at: 38, Ends at:61)
CalledNBR:    |       6 |       |           OK |         6 |
parse_line(Begins at: 3, Ends at:36)
Complexity:   |       6 |       |           OK |         6 |
LOC:          |      34 |       |           OK |        34 |
Clone analysis:
          File :/raster/r.pi/r.pi.import/local_proto.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Tue Aug 10 16:30:09 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
