[GRASS-QA] GRASS QA: mmetz |open.c | 2 clones | 1 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Aug 12 13:30:33 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43072
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/open.c
          Function
Vect__open_old(Begins at: 131, Ends at:474)
              |          New Metrics           |Old Metrics|
Complexity:   |      44 |   *** |      MONSTER |        44 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |     130 |   *** |      MONSTER |       130 |
LOC:          |     344 |   *** |      MONSTER |       344 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect_open_topo(Begins at: 874, Ends at:945)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      72 |     * |      WARNING |        72 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file has 2 potentially cloned functions:
  Vect_open_topo
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect__open_old are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect__open_old
In /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c clones of Vect_open_topo are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_topo
____________________________________________
Threshold grass key metrics values at Thu Aug 12 13:30:31 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
