[GRASS-QA] GRASS QA: mmetz |parse.c | no clones | 1 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Aug 14 14:29:11 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43111
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/dglib/examples/parse.c
          Function
main(Begins at: 87, Ends at:509)
              |          New Metrics           |Old Metrics|
Complexity:   |      57 |   *** |      MONSTER |        57 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     152 |   *** |      MONSTER |       152 |
LOC:          |     423 |   *** |      MONSTER |       423 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Aug 14 14:29:08 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
