[GRASS-QA] GRASS QA: pitanga |global.h entity.c main.c | no clones | 2 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Aug 20 18:33:53 EDT 2010
Hello pitanga,
here's a report on your recent grass-SVN change for the revision : 43170
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.in.redwg/global.h
The system don't find class, method and function
 in this file during analysis!
          File :/vector/v.in.redwg/entity.c
          Function
getEntTypeName(Begins at: 48, Ends at:184)
              |          New Metrics           |Old Metrics|
Complexity:   |      43 |   *** |      MONSTER |        43 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      30 |     * |      WARNING |        30 |
LOC:          |     137 |     * |      WARNING |       137 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
is_low_level(Begins at: 305, Ends at:313)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a            OK           |
metrics are OK
write_entity(Begins at: 315, Ends at:534)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      54 |    ** | BABY-MONSTER |        54 |
LOC:          |     220 |    ** | BABY-MONSTER |       220 |
Conclusion:   | this function is a  BABY-MONSTER           |
write_line(Begins at: 186, Ends at:302)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      47 |    ** | BABY-MONSTER |        47 |
LOC:          |     117 |     * |      WARNING |       117 |
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.in.redwg/main.c
          Function
import_object(Begins at: 260, Ends at:299)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      40 |       |           OK |        40 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
list_layers(Begins at: 230, Ends at:258)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
main(Begins at: 53, Ends at:228)
Complexity:   |      13 |     * |      WARNING |        13 |
CalledNBR:    |      82 |   *** |      MONSTER |        82 |
LOC:          |     176 |    ** | BABY-MONSTER |       176 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Aug 20 18:33:49 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
