[GRASS-QA] GRASS QA: martinl |main.cpp | 1 clones | 0 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Aug 24 13:00:02 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 43243
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.atcorr/main.cpp
          Class
IntPair(Begins at: 218, Ends at:232)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      5 |      2 |      0 |      1 |
|OLD Metrics |      1 |      0 |      5 |      2 |      0 |      1 |
          Class
Options(Begins at: 48, Ends at:67)
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Position(Begins at: 187, Ends at:193)
|NEW Metrics |      1 |      0 |      2 |      2 |      0 |      1 |
|OLD Metrics |      1 |      0 |      2 |      2 |      0 |      1 |
          Class
ScaleRange(Begins at: 69, Ends at:73)
          Class
TICache(Begins at: 129, Ends at:161)
|NEW Metrics |      1 |      0 |      8 |      4 |      0 |      2 |
|OLD Metrics |      1 |      0 |      8 |      4 |      0 |      2 |
          Class
TIMap(Begins at: 173, Ends at:215)
|NEW Metrics |      1 |      0 |      8 |      7 |      0 |      4 |
|OLD Metrics |      1 |      0 |      8 |      7 |      0 |      4 |
          Function
define_options(Begins at: 453, Ends at:524)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      30 |     * |      WARNING |        30 |
LOC:          |      72 |     * |      WARNING |        72 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of define_options are:
          /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp  define_options
____________________________________________
Threshold grass key metrics values at Tue Aug 24 12:59:58 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
