[GRASS-QA] GRASS QA: jarekj71 |memory.c main.c slope_aspect.c | no clones | 0 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Jul 10 12:10:31 EDT 2010
Hello jarekj71,
here's a report on your recent grass-SVN change for the revision : 42540
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.convergence/memory.c
          Function
open_map(Begins at: 3, Ends at:46)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      44 |       |           OK |        44 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.convergence/main.c
          Function
main(Begins at: 21, Ends at:183)
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      65 |    ** | BABY-MONSTER |        65 |
LOC:          |     163 |    ** | BABY-MONSTER |       163 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/raster/r.convergence/slope_aspect.c
          Function
get_distance(Begins at: 2, Ends at:29)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 12:10:22 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        10 |        22 |        34 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        20 |        47 |        74 |
LOC:                  |        72 |       163 |       255 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
