[GRASS-QA] GRASS QA: martinl |main.c args.c lights.c position.c ...| no clones | 1 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Jul 10 15:36:29 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 42627
ANALYSIS
your changes to files/class/methods/functions :
          File :/visualization/nviz2/cmd/main.c
          Function
main(Begins at: 30, Ends at:192)
              |          New Metrics           |Old Metrics|
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      82 |   *** |      MONSTER |        82 |
LOC:          |     163 |    ** | BABY-MONSTER |       163 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/visualization/nviz2/cmd/args.c
          Function
args_lighting(Begins at: 564, Ends at:602)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      39 |       |           OK |        39 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :/lib/nviz/lights.c
          Function
Nviz_set_light_color(Begins at: 88, Ends at:107)
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      20 |       |           OK |        20 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Nviz_set_light_ambient(Begins at: 116, Ends at:128)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      13 |       |           OK |        13 |
Nviz_set_light_position(Begins at: 27, Ends at:54)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :/lib/nviz/position.c
          Function
Nviz_init_view(Begins at: 23, Ends at:39)
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      17 |       |           OK |        17 |
metrics are OK
Clone analysis:
          File :/include/nviz.h
          Class
render_window(Begins at: 123, Ends at:139)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 15:36:17 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        10 |        22 |        34 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        19 |        44 |        70 |
LOC:                  |        72 |       163 |       255 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
