[GRASS-QA] GRASS QA: mmetz |print_stats.c io.c global.h main.c ...| no clones | 0 monsters |4 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jun 3 07:51:16 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42461
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.stream.stats/print_stats.c
          Function
print_stats(Begins at: 7, Ends at:91)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      24 |     * |      WARNING |        24 |
LOC:          |      85 |     * |      WARNING |        85 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.stream.stats/io.c
          Function
create_maps(Begins at: 29, Ends at:153)
Complexity:   |      25 |    ** | BABY-MONSTER |        25 |
CalledNBR:    |      57 |    ** | BABY-MONSTER |        57 |
LOC:          |     125 |     * |      WARNING |       125 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/raster/r.stream.stats/global.h
The system don't find class, method and function
 in this file during analysis!
          File :/raster/r.stream.stats/main.c
          Function
main(Begins at: 32, Ends at:97)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      19 |       |           OK |        19 |
LOC:          |      66 |       |           OK |        66 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :/raster/r.stream.stats/stats.c
          Function
calculate_basins(Begins at: 153, Ends at:172)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
init_streams(Begins at: 7, Ends at:75)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      69 |       |           OK |        69 |
 at least 1 values are close to an outlier please consider revising code!
fill_basin(Begins at: 175, Ends at:208)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      34 |       |           OK |        34 |
metrics are OK
stats(Begins at: 238, Ends at:460)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |     223 |    ** | BABY-MONSTER |       223 |
fifo_return_del(Begins at: 219, Ends at:224)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
calculate_streams(Begins at: 77, Ends at:151)
Complexity:   |       6 |       |           OK |         6 |
LOC:          |      75 |       |           OK |        75 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Jun 03 07:51:12 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        11 |        24 |        38 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        21 |        49 |        78 |
LOC:                  |        80 |       183 |       287 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
