[GRASS-QA] GRASS QA: glynn |waterglobs.h hydro.c output.c main.c ...| no clones | 0 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun May 30 23:36:05 EDT 2010
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 42402
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/simwe/simlib/waterglobs.h
          Class
Point(Begins at: 78, Ends at:82)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Class
flags(Begins at: 61, Ends at:64)
          Class
options(Begins at: 50, Ends at:57)
          Class
seed(Begins at: 68, Ends at:71)
Clone analysis:
This file does not contain cloned functions
          File :/raster/simwe/simlib/hydro.c
The system don't find class, method and function
 in this file during analysis!
          File :/raster/simwe/simlib/output.c
          Function
output_et(Begins at: 578, Ends at:719)
              |          New Metrics           |Old Metrics|
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |      33 |     * |      WARNING |        33 |
LOC:          |     142 |     * |      WARNING |       142 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :/raster/simwe/r.sim.sediment/main.c
          File :/raster/simwe/r.sim.water/main.c
____________________________________________
Threshold grass key metrics values at Sun May 30 23:35:42 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        11 |        26 |        41 |
ParamNBR:             |         4 |         8 |        13 |
CalledNBR:            |        21 |        49 |        78 |
LOC:                  |        78 |       178 |       279 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
