[GRASS-QA] GRASS QA: glynn |r.in.png.c main.c | no clones | 1 monsters |4 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 3 03:38:12 EDT 2010
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 43926
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.in.png/r.in.png.c
The system don't find class, method and function
 in this file during analysis!
          File :/raster/r.in.png/main.c
          Function
gamma_correct(Begins at: 70, Ends at:73)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
get_byte(Begins at: 80, Ends at:83)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
get_png_val(Begins at: 85, Ends at:90)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
init_channel(Begins at: 92, Ends at:108)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      17 |       |           OK |        17 |
metrics are OK
intensity(Begins at: 75, Ends at:78)
metrics are OK
main(Begins at: 512, Ends at:568)
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      57 |       |           OK |        57 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
print_header(Begins at: 235, Ends at:281)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      47 |       |           OK |        47 |
read_png(Begins at: 283, Ends at:510)
Complexity:   |      35 |   *** |      MONSTER |        35 |
CalledNBR:    |      68 |    ** | BABY-MONSTER |        68 |
LOC:          |     228 |    ** | BABY-MONSTER |       228 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
write_colors_float(Begins at: 219, Ends at:233)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
write_colors_int(Begins at: 182, Ends at:217)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      36 |       |           OK |        36 |
metrics are OK
write_row_float(Begins at: 141, Ends at:180)
Complexity:   |      15 |     * |      WARNING |        15 |
LOC:          |      40 |       |           OK |        40 |
write_row_int(Begins at: 110, Ends at:139)
Complexity:   |      11 |     * |      WARNING |        11 |
LOC:          |      30 |       |           OK |        30 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Nov 03 03:37:56 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        68 |       153 |       239 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
