[GRASS-QA] GRASS QA: mmetz |main.c lanczos.c r.proj.h | no clones | 0 monsters |6 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 3 09:46:01 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 44062
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.proj/main.c
The system don't find class, method and function
 in this file during analysis!
          File :/raster/r.proj/lanczos.c
          Function
p_lanczos(Begins at: 20, Ends at:65)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      46 |       |           OK |        46 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
p_lanczos_f(Begins at: 67, Ends at:109)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      43 |       |           OK |        43 |
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.proj/r.proj.h
          Class
cache(Begins at: 17, Ends at:25)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Class
menu(Begins at: 30, Ends at:35)
          Function
BKIDX(Begins at: 73, Ends at:76)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
BKPTR(Begins at: 78, Ends at:81)
CalledNBR:    |       1 |       |           OK |         1 |
BLOCK(Begins at: 83, Ends at:86)
CalledNBR:    |       4 |       |           OK |         4 |
CPTR(Begins at: 88, Ends at:91)
CalledNBR:    |       5 |       |           OK |         5 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Nov 03 09:45:54 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        67 |       151 |       235 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
