[GRASS-QA] GRASS QA: martinl |args.c list.c status.c link.c ...| 1 clones | 0 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Nov 30 00:58:22 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44479
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.external.out/args.c
          Function
parse_args(Begins at: 8, Ends at:58)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      51 |       |           OK |        51 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.external.out/list.c
          Function
format_list(Begins at: 6, Ends at:44)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      39 |       |           OK |        39 |
Conclusion:   | this function is a            OK           |
metrics are OK
list_formats(Begins at: 46, Ends at:65)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
Clone analysis:
          File :/vector/v.external.out/status.c
          Function
print_status(Begins at: 6, Ends at:38)
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Clone analysis:
          File :/vector/v.external.out/link.c
          Function
make_link(Begins at: 7, Ends at:59)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      17 |       |           OK |        17 |
LOC:          |      53 |       |           OK |        53 |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.external.out/link.c clones of make_link are:
          /data/project-manager/grass/grassSVN/grass/trunk/raster/r.external.out/main.c  make_link
          File :/vector/v.external.out/main.c
          Function
main(Begins at: 26, Ends at:68)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      43 |       |           OK |        43 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :/vector/v.external.out/format.c
          Function
check_format(Begins at: 6, Ends at:17)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Clone analysis:
          File :/vector/v.external.out/local_proto.h
          Class
_flags(Begins at: 8, Ends at:10)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Class
_options(Begins at: 4, Ends at:6)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 30 00:58:01 EST 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        10 |        22 |        34 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        68 |       153 |       239 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
