[GRASS-QA] GRASS QA: martinl |sqlCtype.c xdr.c xdrvalue.c cursor.c ...| 94 clones | 3 monsters |12 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Apr 5 16:13:03 EDT 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45853
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/db/dbmi_base/sqlCtype.c
          Function
db_sqltype_to_Ctype(Begins at: 24, Ends at:48)
              |          New Metrics           |Old Metrics|
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/lib/db/dbmi_base/xdr.c
          Function
db__send(Begins at: 89, Ends at:98)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
db__set_protocol_fds(Begins at: 75, Ends at:79)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/xdrvalue.c
          Function
db__send_value(Begins at: 28, Ends at:52)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |       6 |       |           OK |         6 |
metrics are OK
db__recv_value(Begins at: 62, Ends at:86)
CalledNBR:    |       7 |       |           OK |         7 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/cursor.c
          Function
db_init_cursor(Begins at: 23, Ends at:31)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/xdrint.c
          Function
db__recv_int_array(Begins at: 92, Ends at:112)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      21 |       |           OK |        21 |
metrics are OK
db__recv_int(Begins at: 44, Ends at:55)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
db__send_int(Begins at: 24, Ends at:35)
metrics are OK
db__send_int_array(Begins at: 65, Ends at:79)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Clone analysis:
This file has 20 potentially cloned functions:
  db__recv_float_array  db__recv_short_array  db__recv_char  db__send_double  db__recv_double  db__send_float  db__recv_float  db__send_int  db__recv_short  db__recv_char  db__send_double  db__recv_double  db__send_float  db__recv_float  db__recv_int  db__recv_short  db__send_double_array  db__send_float_array  db__send_short_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c clones of db__recv_int_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdouble.c  db__recv_double_array
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrfloat.c  db__recv_float_array
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrshort.c  db__recv_short_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c clones of db__recv_int are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrchar.c  db__recv_char
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdouble.c  db__send_double
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrfloat.c  db__send_float
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c  db__send_int
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c clones of db__send_int are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c  db__recv_int
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c clones of db__send_int_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdouble.c  db__send_double_array
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrfloat.c  db__send_float_array
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrshort.c  db__send_short_array
          File :/lib/db/dbmi_base/handle.c
The system don't find class, method and function
 in this file during analysis!
          File :/lib/db/dbmi_base/value.c
          Function
db_CatValArray_alloc(Begins at: 401, Ends at:408)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
db_set_value_int(Begins at: 195, Ends at:199)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
db_set_value_minute(Begins at: 279, Ends at:283)
metrics are OK
db_set_value_double(Begins at: 207, Ends at:211)
metrics are OK
db_set_value_hour(Begins at: 267, Ends at:271)
metrics are OK
db_get_value_double(Begins at: 50, Ends at:53)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_set_value_seconds(Begins at: 291, Ends at:295)
metrics are OK
db_set_value_day(Begins at: 255, Ends at:259)
metrics are OK
db_get_value_seconds(Begins at: 164, Ends at:167)
metrics are OK
db_set_value_string(Begins at: 219, Ends at:223)
metrics are OK
db_copy_value(Begins at: 340, Ends at:354)
Complexity:   |       2 |       |           OK |         2 |
metrics are OK
db_get_value_year(Begins at: 104, Ends at:107)
metrics are OK
db_set_value_year(Begins at: 231, Ends at:235)
metrics are OK
db_CatValArray_realloc(Begins at: 420, Ends at:427)
metrics are OK
db_set_value_month(Begins at: 243, Ends at:247)
metrics are OK
db_set_value_datetime_current(Begins at: 315, Ends at:319)
metrics are OK
db_set_value_not_null(Begins at: 184, Ends at:187)
metrics are OK
db_test_value_datetime_current(Begins at: 305, Ends at:308)
metrics are OK
db_get_value_month(Begins at: 116, Ends at:119)
metrics are OK
db_get_value_day(Begins at: 128, Ends at:131)
metrics are OK
db_set_value_datetime_not_current(Begins at: 326, Ends at:330)
metrics are OK
db_get_value_as_double(Begins at: 65, Ends at:83)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
db_set_value_null(Begins at: 174, Ends at:177)
metrics are OK
db_test_value_isnull(Begins at: 26, Ends at:29)
metrics are OK
db_CatValArray_init(Begins at: 361, Ends at:366)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
db_CatValArray_free(Begins at: 373, Ends at:389)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      17 |       |           OK |        17 |
metrics are OK
db_get_value_hour(Begins at: 140, Ends at:143)
metrics are OK
db_get_value_minute(Begins at: 152, Ends at:155)
metrics are OK
db_get_value_int(Begins at: 38, Ends at:41)
metrics are OK
db_get_value_string(Begins at: 92, Ends at:95)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/columnfmt.c
          Function
db_convert_Cstring_to_column_default_value(Begins at: 43, Ends at:51)
metrics are OK
db_convert_column_default_value_to_string(Begins at: 79, Ends at:87)
metrics are OK
db_convert_column_value_to_string(Begins at: 61, Ends at:69)
metrics are OK
db_convert_Cstring_to_column_value(Begins at: 25, Ends at:33)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/datetime.c
          Function
db_convert_Cstring_to_value_datetime(Begins at: 197, Ends at:330)
Complexity:   |      45 |   *** |      MONSTER |        45 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      33 |     * |      WARNING |        33 |
LOC:          |     134 |     * |      WARNING |       134 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
db_convert_value_datetime_into_string(Begins at: 31, Ends at:175)
Complexity:   |      49 |   *** |      MONSTER |        49 |
CalledNBR:    |      34 |     * |      WARNING |        34 |
LOC:          |     145 |    ** | BABY-MONSTER |       145 |
Clone analysis:
          File :/lib/db/dbmi_base/default_name.c
          File :/lib/db/dbmi_base/zero.c
          Function
db_zero(Begins at: 23, Ends at:29)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/string.c
          Function
db_init_string(Begins at: 25, Ends at:29)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/sqltype.c
          Function
db_sqltype_name(Begins at: 25, Ends at:121)
Complexity:   |      35 |   *** |      MONSTER |        35 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      97 |     * |      WARNING |        97 |
Clone analysis:
          File :/lib/db/dbmi_base/xdrhandle.c
          Function
db__send_handle(Begins at: 25, Ends at:31)
metrics are OK
db__recv_handle(Begins at: 40, Ends at:46)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/ret_codes.c
          Function
db__send_success(Begins at: 26, Ends at:30)
ParamNBR:     |       0 |       |           OK |         0 |
metrics are OK
db__recv_return_code(Begins at: 51, Ends at:75)
metrics are OK
db__send_failure(Begins at: 37, Ends at:42)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/xdrfloat.c
          Function
db__send_float_array(Begins at: 65, Ends at:79)
metrics are OK
db__recv_float_array(Begins at: 92, Ends at:112)
metrics are OK
db__recv_float(Begins at: 44, Ends at:55)
metrics are OK
db__send_float(Begins at: 24, Ends at:35)
metrics are OK
Clone analysis:
  db__send_int_array  db__send_short_array  db__recv_double_array  db__recv_int_array  db__recv_short_array  db__recv_char  db__send_double  db__recv_double  db__send_float  db__send_int  db__recv_int  db__recv_short  db__recv_char  db__send_double  db__recv_double  db__recv_float  db__send_int  db__recv_int  db__recv_short
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrfloat.c clones of db__send_float_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c  db__send_int_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrfloat.c clones of db__recv_float_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrint.c  db__recv_int_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrfloat.c clones of db__recv_float are:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrfloat.c clones of db__send_float are:
          File :/lib/db/dbmi_base/xdrtable.c
          Function
db__send_table_definition(Begins at: 26, Ends at:42)
metrics are OK
db__recv_table_data(Begins at: 101, Ends at:117)
metrics are OK
db__send_table_data(Begins at: 81, Ends at:92)
metrics are OK
db__recv_table_definition(Begins at: 51, Ends at:72)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      22 |       |           OK |        22 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/error.c
          Function
db_set_error_who(Begins at: 46, Ends at:51)
metrics are OK
db_get_error_code(Begins at: 126, Ends at:129)
metrics are OK
db_syserror(Begins at: 101, Ends at:119)
metrics are OK
db_print_error(Begins at: 183, Ends at:202)
LOC:          |      20 |       |           OK |        20 |
metrics are OK
db_debug_on(Begins at: 210, Ends at:213)
metrics are OK
db_debug_off(Begins at: 218, Ends at:221)
metrics are OK
db_auto_print_protocol_errors(Begins at: 260, Ends at:263)
metrics are OK
db_auto_print_errors(Begins at: 249, Ends at:253)
metrics are OK
db_debug(Begins at: 228, Ends at:232)
metrics are OK
db_noproc_error(Begins at: 159, Ends at:166)
metrics are OK
db_memory_error(Begins at: 134, Ends at:138)
metrics are OK
db_get_error_who(Begins at: 59, Ends at:62)
metrics are OK
db_protocol_error(Begins at: 85, Ends at:94)
metrics are OK
db_clear_error(Begins at: 171, Ends at:176)
metrics are OK
db_error(Begins at: 69, Ends at:80)
metrics are OK
db_procedure_not_implemented(Begins at: 145, Ends at:152)
metrics are OK
db_get_error_msg(Begins at: 239, Ends at:242)
metrics are OK
db_on_error(Begins at: 36, Ends at:39)
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/error.c clones of db_protocol_error are:
          /data/project-manager/grass/grassSVN/grass-addons/imagery/gipe/i.eb.disp/disp.c  dis_p
          File :/lib/db/dbmi_client/c_bindupdate.c
          Function
db_bind_update(Begins at: 26, Ends at:47)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/whoami.c
          Function
db_whoami(Begins at: 26, Ends at:29)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/table.c
          Function
db_get_table_description(Begins at: 125, Ends at:128)
metrics are OK
db_set_table_column(Begins at: 353, Ends at:359)
db_get_table_insert_priv(Begins at: 260, Ends at:263)
metrics are OK
db_table_to_sql(Begins at: 423, Ends at:494)
Complexity:   |      17 |     * |      WARNING |        17 |
CalledNBR:    |      28 |     * |      WARNING |        28 |
LOC:          |      72 |     * |      WARNING |        72 |
 at least 3 values are close to an outlier please consider revising code!
db_get_table_update_priv(Begins at: 228, Ends at:231)
metrics are OK
db_set_table_insert_priv_not_granted(Begins at: 248, Ends at:251)
metrics are OK
db_get_table_delete_priv(Begins at: 292, Ends at:295)
metrics are OK
db_set_table_insert_priv_granted(Begins at: 238, Ends at:241)
metrics are OK
db_init_table(Begins at: 56, Ends at:61)
metrics are OK
db_get_table_column_by_name(Begins at: 322, Ends at:340)
metrics are OK
db_alloc_table(Begins at: 28, Ends at:49)
metrics are OK
db_set_table_select_priv_granted(Begins at: 174, Ends at:177)
metrics are OK
db_set_table_select_priv_not_granted(Begins at: 184, Ends at:187)
metrics are OK
db_set_table_name(Begins at: 88, Ends at:91)
metrics are OK
db_get_table_number_of_columns(Begins at: 137, Ends at:140)
metrics are OK
db_append_table_column(Begins at: 371, Ends at:379)
metrics are OK
db_set_table_delete_priv_granted(Begins at: 270, Ends at:273)
metrics are OK
db_set_table_update_priv_not_granted(Begins at: 216, Ends at:219)
metrics are OK
db_get_table_name(Begins at: 100, Ends at:103)
metrics are OK
set_all_column_privs(Begins at: 142, Ends at:152)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
get_all_column_privs(Begins at: 154, Ends at:167)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
db_clone_table(Begins at: 391, Ends at:412)
metrics are OK
db_free_table(Begins at: 68, Ends at:78)
metrics are OK
db_set_table_update_priv_granted(Begins at: 206, Ends at:209)
metrics are OK
db_set_table_delete_priv_not_granted(Begins at: 280, Ends at:283)
metrics are OK
db_get_table_select_priv(Begins at: 196, Ends at:199)
metrics are OK
db_set_table_description(Begins at: 113, Ends at:116)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/login.c
          Function
db_get_login(Begins at: 227, Ends at:261)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      35 |       |           OK |        35 |
db_set_login(Begins at: 173, Ends at:213)
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      41 |       |           OK |        41 |
write_file(Begins at: 128, Ends at:160)
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  db_set_login
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/login.c clones of db_get_login are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/login.c  db_get_login
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/login.c clones of db_set_login are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/login.c  db_set_login
          File :/lib/db/dbmi_base/legal_dbname.c
          Function
db_legal_tablename(Begins at: 31, Ends at:60)
LOC:          |      30 |       |           OK |        30 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/column.c
          Function
db_copy_column(Begins at: 473, Ends at:498)
LOC:          |      26 |       |           OK |        26 |
metrics are OK
db_set_column_sqltype(Begins at: 71, Ends at:74)
metrics are OK
db_set_column_precision(Begins at: 128, Ends at:131)
metrics are OK
db_get_column_value(Begins at: 27, Ends at:30)
metrics are OK
db_get_column_sqltype(Begins at: 142, Ends at:145)
metrics are OK
db_get_column_default_value(Begins at: 39, Ends at:42)
metrics are OK
db_set_column_has_undefined_default_value(Begins at: 176, Ends at:179)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/strip.c
          Function
db_strip(Begins at: 25, Ends at:41)
Complexity:   |       7 |       |           OK |         7 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/xdrcolumn.c
          Function
db__recv_column_value(Begins at: 94, Ends at:98)
metrics are OK
db__recv_column_default_value(Begins at: 120, Ends at:124)
metrics are OK
db__recv_column_definition(Begins at: 53, Ends at:72)
CalledNBR:    |      13 |       |           OK |        13 |
metrics are OK
db__send_column_definition(Begins at: 25, Ends at:44)
metrics are OK
db__send_column_default_value(Begins at: 107, Ends at:111)
metrics are OK
db__send_column_value(Begins at: 81, Ends at:85)
metrics are OK
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrcolumn.c clones of db__recv_column_definition are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrcolumn.c  db__send_column_definition
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrcolumn.c clones of db__send_column_definition are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrcolumn.c  db__recv_column_definition
          File :/lib/db/dbmi_base/dbmscap.c
          Function
db_read_dbmscap(Begins at: 100, Ends at:204)
CalledNBR:    |      31 |     * |      WARNING |        31 |
LOC:          |     105 |     * |      WARNING |       105 |
 at least 2 values are close to an outlier please consider revising code!
add_entry(Begins at: 206, Ends at:233)
LOC:          |      28 |       |           OK |        28 |
Clone analysis:
          File :/lib/db/dbmi_base/case.c
          Function
db_nocase_compare(Begins at: 69, Ends at:82)
metrics are OK
db_Cstring_to_lowercase(Begins at: 44, Ends at:48)
metrics are OK
db_char_to_lowercase(Begins at: 22, Ends at:26)
metrics are OK
db_char_to_uppercase(Begins at: 33, Ends at:37)
metrics are OK
db_Cstring_to_uppercase(Begins at: 55, Ends at:59)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/connect.c
          Function
db_set_connection(Begins at: 28, Ends at:59)
LOC:          |      32 |       |           OK |        32 |
metrics are OK
db_get_connection(Begins at: 68, Ends at:85)
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/isdir.c
          Function
db_isdir(Begins at: 29, Ends at:36)
metrics are OK
Clone analysis:
          File :/include/dbmidefs.h
          File :/include/dbmi.h
          File :/lib/db/dbmi_base/interval.c
          Function
db_interval_range(Begins at: 24, Ends at:70)
Complexity:   |      18 |     * |      WARNING |        18 |
LOC:          |      47 |       |           OK |        47 |
Clone analysis:
          File :/lib/db/dbmi_base/alloc.c
          Function
db_calloc(Begins at: 69, Ends at:81)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
db_free(Begins at: 111, Ends at:114)
metrics are OK
db_malloc(Begins at: 47, Ends at:57)
metrics are OK
db_realloc(Begins at: 93, Ends at:104)
metrics are OK
db_store(Begins at: 28, Ends at:36)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/xdrindex.c
          Function
db__recv_index(Begins at: 69, Ends at:88)
metrics are OK
db__recv_index_array(Begins at: 96, Ends at:111)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
db__send_index(Begins at: 26, Ends at:41)
metrics are OK
db__send_index_array(Begins at: 51, Ends at:60)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/xdrchar.c
          Function
db__recv_char(Begins at: 45, Ends at:56)
metrics are OK
db__send_char(Begins at: 24, Ends at:36)
metrics are OK
Clone analysis:
This file has 8 potentially cloned functions:
  db__recv_double  db__send_float  db__recv_float  db__send_int  db__recv_int  db__recv_short  db__send_short
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrchar.c clones of db__recv_char are:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrchar.c clones of db__send_char are:
          File :/lib/db/dbmi_base/xdrdouble.c
          Function
db__recv_double(Begins at: 42, Ends at:53)
metrics are OK
db__recv_double_array(Begins at: 90, Ends at:110)
metrics are OK
db__send_double(Begins at: 24, Ends at:35)
metrics are OK
db__send_double_array(Begins at: 63, Ends at:77)
metrics are OK
Clone analysis:
  db__send_double  db__send_float  db__recv_float  db__send_int  db__recv_int  db__recv_short  db__recv_float_array  db__recv_int_array  db__recv_short_array  db__recv_char  db__recv_double  db__send_float  db__recv_float  db__send_int  db__recv_int  db__recv_short  db__send_float_array  db__send_int_array  db__send_short_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdouble.c clones of db__recv_double are:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdouble.c clones of db__recv_double_array are:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdouble.c clones of db__send_double are:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdouble.c clones of db__send_double_array are:
          File :/lib/db/dbmi_base/xdrprocedure.c
          Function
db__recv_procnum(Begins at: 52, Ends at:60)
metrics are OK
db__send_procedure_not_implemented(Begins at: 81, Ends at:84)
metrics are OK
db__send_procedure_ok(Begins at: 69, Ends at:72)
metrics are OK
db__start_procedure_call(Begins at: 25, Ends at:42)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/xdrtoken.c
          Function
db__recv_token(Begins at: 36, Ends at:39)
metrics are OK
db__send_token(Begins at: 24, Ends at:27)
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/dirent.c
          Function
cmp_dirent(Begins at: 144, Ends at:151)
metrics are OK
db_alloc_dirent_array(Begins at: 166, Ends at:179)
metrics are OK
db_dirent(Begins at: 51, Ends at:109)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      59 |       |           OK |        59 |
db_free_dirent_array(Begins at: 117, Ends at:126)
metrics are OK
get_perm(Begins at: 128, Ends at:142)
metrics are OK
sort_dirent(Begins at: 153, Ends at:156)
metrics are OK
Clone analysis:
  db_free_index_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/dirent.c clones of db_free_dirent_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/handle.c  db_free_handle_array
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/index.c  db_free_index_array
          File :/lib/db/dbmi_base/xdrstring.c
          Function
db__recv_string(Begins at: 117, Ends at:141)
metrics are OK
db__recv_string_array(Begins at: 46, Ends at:77)
metrics are OK
db__send_Cstring(Begins at: 150, Ends at:158)
metrics are OK
db__send_string(Begins at: 86, Ends at:105)
metrics are OK
db__send_string_array(Begins at: 26, Ends at:36)
metrics are OK
Clone analysis:
          File :/include/proto_dbmi.h
          File :/lib/db/dbmi_base/valuefmt.c
          Function
db_convert_Cstring_to_value(Begins at: 31, Ends at:56)
db_convert_value_to_string(Begins at: 67, Ends at:96)
CalledNBR:    |      12 |       |           OK |        12 |
Clone analysis:
          File :/lib/db/dbmi_base/index.c
          Function
db_alloc_index_array(Begins at: 73, Ends at:84)
metrics are OK
db_alloc_index_columns(Begins at: 56, Ends at:64)
metrics are OK
db_free_index(Begins at: 39, Ends at:46)
metrics are OK
db_free_index_array(Begins at: 92, Ends at:101)
metrics are OK
db_get_index_column_name(Begins at: 194, Ends at:201)
metrics are OK
db_get_index_name(Begins at: 124, Ends at:127)
metrics are OK
db_get_index_number_of_columns(Begins at: 162, Ends at:165)
metrics are OK
db_get_index_table_name(Begins at: 150, Ends at:153)
metrics are OK
db_init_index(Begins at: 25, Ends at:32)
metrics are OK
db_print_index(Begins at: 254, Ends at:270)
metrics are OK
db_set_index_column_name(Begins at: 177, Ends at:184)
db_set_index_name(Begins at: 112, Ends at:115)
metrics are OK
db_set_index_table_name(Begins at: 138, Ends at:141)
metrics are OK
db_set_index_type_non_unique(Begins at: 228, Ends at:233)
metrics are OK
db_set_index_type_unique(Begins at: 212, Ends at:217)
metrics are OK
db_test_index_type_unique(Begins at: 243, Ends at:246)
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  db_free_handle_array  db_free_string_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/index.c clones of db_free_index_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/dirent.c  db_free_dirent_array
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/string.c  db_free_string_array
          File :/lib/db/dbmi_base/xdrshort.c
          Function
db__recv_short(Begins at: 46, Ends at:57)
metrics are OK
db__recv_short_array(Begins at: 94, Ends at:114)
metrics are OK
db__send_short(Begins at: 25, Ends at:37)
metrics are OK
db__send_short_array(Begins at: 67, Ends at:81)
metrics are OK
Clone analysis:
This file has 14 potentially cloned functions:
  db__send_double  db__recv_double  db__send_float  db__recv_float  db__send_int  db__recv_int  db__recv_double_array  db__recv_float_array  db__recv_int_array  db__send_char  db__send_double_array  db__send_float_array  db__send_int_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrshort.c clones of db__recv_short are:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrshort.c clones of db__recv_short_array are:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrshort.c clones of db__send_short are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrchar.c  db__send_char
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrshort.c clones of db__send_short_array are:
          File :/lib/db/dbmi_base/xdrdatetime.c
          Function
db__recv_datetime(Begins at: 47, Ends at:60)
metrics are OK
db__send_datetime(Begins at: 25, Ends at:38)
metrics are OK
Clone analysis:
  db__recv_datetime
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdatetime.c clones of db__recv_datetime are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdatetime.c  db__send_datetime
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdatetime.c clones of db__send_datetime are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/xdrdatetime.c  db__recv_datetime
____________________________________________
Threshold grass key metrics values at Tue Apr 05 16:12:49 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
