[GRASS-QA] GRASS QA: mmetz |e_intersect.c dgraph.c buffer2.c | no clones | 3 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Apr 8 04:48:12 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45874
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/vector/Vlib/e_intersect.c
The system don't find class, method and function
 in this file during analysis!
          File :/lib/vector/Vlib/dgraph.c
          Class
intersection_point(Begins at: 33, Ends at:38)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
seg_intersection(Begins at: 40, Ends at:45)
          Class
seg_intersection_list(Begins at: 47, Ends at:52)
          Class
seg_intersections(Begins at: 54, Ends at:62)
          Function
find_all_intersections(Begins at: 218, Ends at:346)
              |          New Metrics           |Old Metrics|
Complexity:   |      18 |     * |      WARNING |        18 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      30 |     * |      WARNING |        30 |
LOC:          |     129 |     * |      WARNING |       129 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :/lib/vector/Vlib/buffer2.c
          Function
buffer_lines(Begins at: 845, Ends at:979)
ParamNBR:     |      13 |   *** |      MONSTER |        13 |
CalledNBR:    |      49 |    ** | BABY-MONSTER |        49 |
LOC:          |     135 |     * |      WARNING |       135 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect_line_buffer2(Begins at: 998, Ends at:1046)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |      10 |   *** |      MONSTER |        10 |
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      49 |       |           OK |        49 |
extract_contour(Begins at: 492, Ends at:623)
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |     132 |     * |      WARNING |       132 |
Conclusion:   | this function is a  BABY-MONSTER           |
convolution_line(Begins at: 339, Ends at:485)
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      40 |    ** | BABY-MONSTER |        40 |
LOC:          |     147 |    ** | BABY-MONSTER |       147 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Apr 08 04:48:09 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        63 |       142 |       222 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
