[GRASS-QA] GRASS QA: hamish |points.c draw.c grid.c main.c ...| no clones | 4 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Apr 27 04:39:59 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 46115
ANALYSIS
your changes to files/class/methods/functions :
          File :/display/d.barb/points.c
          Function
fill_arrays(Begins at: 145, Ends at:277)
              |          New Metrics           |Old Metrics|
Complexity:   |      21 |    ** | BABY-MONSTER |        21 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      39 |     * |      WARNING |        39 |
LOC:          |     133 |     * |      WARNING |       133 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/display/d.barb/draw.c
          Function
draw_feather(Begins at: 208, Ends at:654)
Complexity:   |      44 |   *** |      MONSTER |        44 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |     492 |   *** |      MONSTER |       492 |
LOC:          |     447 |   *** |      MONSTER |       447 |
draw_circle(Begins at: 166, Ends at:202)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      37 |       |           OK |        37 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :/display/d.barb/grid.c
          Function
do_barb_grid(Begins at: 10, Ends at:193)
Complexity:   |      31 |    ** | BABY-MONSTER |        31 |
CalledNBR:    |      47 |    ** | BABY-MONSTER |        47 |
LOC:          |     184 |    ** | BABY-MONSTER |       184 |
Clone analysis:
          File :/display/d.barb/main.c
          Function
main(Begins at: 26, Ends at:263)
Complexity:   |      19 |     * |      WARNING |        19 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      90 |   *** |      MONSTER |        90 |
LOC:          |     238 |   *** |      MONSTER |       238 |
Clone analysis:
          File :/display/d.barb/local_proto.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Wed Apr 27 04:39:56 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
