[GRASS-QA] GRASS QA: mmetz |main.cpp | 1 clones | 0 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Apr 28 08:11:59 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46126
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.atcorr/main.cpp
          Class
Options(Begins at: 63, Ends at:81)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
RBitem(Begins at: 89, Ends at:94)
          Class
ScaleRange(Begins at: 83, Ends at:87)
          Class
TICache(Begins at: 175, Ends at:227)
|NEW Metrics |      1 |      0 |      5 |     11 |      0 |      2 |
|OLD Metrics |      1 |      0 |      5 |     11 |      0 |      2 |
          Function
main(Begins at: 554, Ends at:653)
              |          New Metrics           |Old Metrics|
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      40 |     * |      WARNING |        40 |
LOC:          |     100 |     * |      WARNING |       100 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
define_options(Begins at: 456, Ends at:522)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      28 |     * |      WARNING |        28 |
LOC:          |      67 |     * |      WARNING |        67 |
 at least 2 values are close to an outlier please consider revising code!
process_raster(Begins at: 244, Ends at:409)
Complexity:   |      25 |    ** | BABY-MONSTER |        25 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      42 |    ** | BABY-MONSTER |        42 |
LOC:          |     166 |    ** | BABY-MONSTER |       166 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of define_options are:
          /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp  define_options
____________________________________________
Threshold grass key metrics values at Thu Apr 28 08:11:54 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
