[GRASS-QA] GRASS QA: martinl |cursor.c printwindow.c value.c handle.c ...| 19 clones | 2 monsters |10 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Feb 28 07:08:21 EST 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45484
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/db/dbmi_base/cursor.c
          Function
db_free_cursor_column_flags(Begins at: 299, Ends at:304)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/general/g.region/printwindow.c
The system don't find class, method and function
 in this file during analysis!
          File :/lib/db/dbmi_base/value.c
          Function
db_CatValArray_free(Begins at: 348, Ends at:365)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/handle.c
          Function
db_free_handle_array(Begins at: 91, Ends at:100)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  db_free_index_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/handle.c clones of db_free_handle_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/dirent.c  db_free_dirent_array
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/index.c  db_free_index_array
          File :/lib/db/dbmi_driver/driver_state.c
          Function
db__close_all_cursors(Begins at: 122, Ends at:135)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
db__mark_database_closed(Begins at: 67, Ends at:72)
Complexity:   |       1 |       |           OK |         1 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/string.c
          Function
db_free_string_array(Begins at: 163, Ends at:172)
metrics are OK
db_free_string(Begins at: 150, Ends at:155)
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/string.c clones of db_free_string_array are:
          File :/lib/db/dbmi_base/error.c
          Function
db_set_error_who(Begins at: 33, Ends at:38)
metrics are OK
db_error(Begins at: 57, Ends at:68)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/table.c
          Function
db_alloc_table(Begins at: 11, Ends at:32)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      22 |       |           OK |        22 |
metrics are OK
db_free_table(Begins at: 49, Ends at:59)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/dbmscap.c
          Function
db_free_dbmscap(Begins at: 241, Ends at:249)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
          File :/lib/proj/ftol.c
          Function
_ftol2(Begins at: 2, Ends at:2)
LOC:          |       1 |       |           OK |         1 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/alloc.c
          Function
db_calloc(Begins at: 45, Ends at:57)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
db_free(Begins at: 84, Ends at:87)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
db_malloc(Begins at: 27, Ends at:37)
metrics are OK
db_realloc(Begins at: 65, Ends at:76)
metrics are OK
db_store(Begins at: 11, Ends at:19)
metrics are OK
Clone analysis:
          File :/lib/g3d/g3dcache.c
          Function
G3d_disposeCache(Begins at: 243, Ends at:259)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
G3d_flushAllTiles(Begins at: 278, Ends at:330)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      53 |       |           OK |        53 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
G3d_initCache(Begins at: 215, Ends at:231)
metrics are OK
cacheFlushFun(Begins at: 264, Ends at:274)
ParamNBR:     |       3 |     * |      WARNING |         3 |
 at least 1 values are close to an outlier please consider revising code!
cacheRead_readFun(Begins at: 10, Ends at:19)
cacheWrite_readFun(Begins at: 56, Ends at:130)
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      75 |     * |      WARNING |        75 |
 at least 4 values are close to an outlier please consider revising code!
cacheWrite_writeFun(Begins at: 134, Ends at:164)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      31 |       |           OK |        31 |
disposeCacheRead(Begins at: 235, Ends at:239)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
disposeCacheWrite(Begins at: 168, Ends at:182)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
initCacheRead(Begins at: 23, Ends at:34)
metrics are OK
initCacheWrite(Begins at: 186, Ends at:211)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
  cacheFlushFun
In /data/project-manager/grass/grassSVN/grass/trunk/lib/g3d/g3dcache.c clones of cacheFlushFun are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/g3d/g3dcache.c  cacheRead_readFun
In /data/project-manager/grass/grassSVN/grass/trunk/lib/g3d/g3dcache.c clones of cacheRead_readFun are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/g3d/g3dcache.c  cacheFlushFun
          File :/include/gprojects.h
          Class
DERIVS(Begins at: 116, Ends at:119)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Class
FACTORS(Begins at: 121, Ends at:129)
          Class
gpj_datum(Begins at: 41, Ends at:45)
          Class
gpj_datum_transform_list(Begins at: 47, Ends at:61)
          Class
gpj_ellps(Begins at: 63, Ends at:67)
          Class
pj_info(Begins at: 33, Ends at:39)
Clone analysis:
          File :/lib/db/dbmi_base/dirent.c
          Function
cmp_dirent(Begins at: 128, Ends at:135)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
db_alloc_dirent_array(Begins at: 148, Ends at:161)
metrics are OK
db_dirent(Begins at: 35, Ends at:93)
LOC:          |      59 |       |           OK |        59 |
db_free_dirent_array(Begins at: 101, Ends at:110)
metrics are OK
get_perm(Begins at: 112, Ends at:126)
metrics are OK
sort_dirent(Begins at: 137, Ends at:140)
metrics are OK
Clone analysis:
  db_free_index_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/dirent.c clones of db_free_dirent_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/handle.c  db_free_handle_array
          File :/include/proto_dbmi.h
          File :/lib/db/dbmi_driver/d_close_cur.c
          Function
db_d_close_cursor(Begins at: 26, Ends at:58)
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_client/copy_tab.c
          Function
cmp(Begins at: 21, Ends at:31)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
db__copy_table(Begins at: 58, Ends at:388)
Complexity:   |      49 |   *** |      MONSTER |        49 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |     158 |   *** |      MONSTER |       158 |
LOC:          |     331 |   *** |      MONSTER |       331 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
db_copy_table(Begins at: 403, Ends at:410)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
Conclusion:   | this function is a  BABY-MONSTER           |
db_copy_table_by_ints(Begins at: 476, Ends at:484)
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
db_copy_table_select(Begins at: 450, Ends at:458)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
db_copy_table_where(Begins at: 426, Ends at:434)
Clone analysis:
This file has 9 potentially cloned functions:
  srch  cmp  cmp  cmp_exist  cmp  cmp  srch  srch_cat
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/copy_tab.c clones of cmp are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/array.c  cmp
          /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/ascii.c  srch
          /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cats.c  cmp
          /data/project-manager/grass/grassSVN/grass/trunk/raster/r.li/r.li.pielou/pielou.c  cmp
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c  cmp_exist
          /data/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/main.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/main.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.3d/trans3.c  srch
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.what.rast/main.c  srch_cat
          File :/lib/db/dbmi_client/shutdown.c
          Function
db_shutdown_driver(Begins at: 39, Ends at:76)
LOC:          |      38 |       |           OK |        38 |
metrics are OK
Clone analysis:
          File :/lib/db/dbmi_base/index.c
          Function
db_alloc_index_array(Begins at: 57, Ends at:68)
metrics are OK
db_alloc_index_columns(Begins at: 41, Ends at:49)
metrics are OK
db_free_index(Begins at: 26, Ends at:33)
metrics are OK
db_free_index_array(Begins at: 76, Ends at:85)
metrics are OK
db_get_index_column_name(Begins at: 164, Ends at:171)
metrics are OK
db_get_index_name(Begins at: 104, Ends at:107)
metrics are OK
db_get_index_number_of_columns(Begins at: 137, Ends at:140)
metrics are OK
db_get_index_table_name(Begins at: 126, Ends at:129)
metrics are OK
db_init_index(Begins at: 11, Ends at:18)
metrics are OK
db_print_index(Begins at: 216, Ends at:232)
CalledNBR:    |      11 |       |           OK |        11 |
metrics are OK
db_set_index_column_name(Begins at: 148, Ends at:156)
db_set_index_name(Begins at: 93, Ends at:96)
metrics are OK
db_set_index_table_name(Begins at: 115, Ends at:118)
metrics are OK
db_set_index_type_non_unique(Begins at: 192, Ends at:197)
metrics are OK
db_set_index_type_unique(Begins at: 179, Ends at:184)
metrics are OK
db_test_index_type_unique(Begins at: 205, Ends at:208)
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  db_free_handle_array  db_free_string_array
In /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/index.c clones of db_free_index_array are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_base/string.c  db_free_string_array
____________________________________________
Threshold grass key metrics values at Mon Feb 28 07:08:15 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
