[GRASS-QA] GRASS QA: mmetz |main.c global.h main.c main.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jan 20 11:41:09 EST 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45107
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.info/main.c
The system don't find class, method and function
 in this file during analysis!
          File :/vector/v.in.dxf/global.h
          Class
dxf_file(Begins at: 10, Ends at:18)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.outlier/main.c
          File :/vector/v.in.ogr/main.c
          File :/vector/v.out.vtk/writeVTK.c
          File :/vector/v.surf.bspline/crosscorr.c
          File :/vector/v.lidar.growing/main.c
          File :/vector/v.what/main.c
          File :/vector/v.mapcalc/map.c
          File :/vector/v.external/main.c
          File :/vector/v.lidar.edgedetection/main.c
          File :/vector/v.in.dxf/read_dxf.c
          File :/vector/v.external.out/main.c
          File :/vector/v.lidar.correction/main.c
          File :/vector/v.vol.rst/user1.c
          File :/vector/v.vol.rst/user3.c
          File :/vector/v.out.ogr/main.c
          File :/vector/v.surf.bspline/main.c
          File :/vector/v.select/main.c
____________________________________________
Threshold grass key metrics values at Thu Jan 20 11:41:00 EST 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       146 |       227 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
