[GRASS-QA] GRASS QA: huhabla |erod.c waterglobs.h hydro.c output.c ...| no clones | 5 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Mar 13 13:17:12 EDT 2011
Hello huhabla,
here's a report on your recent grass-SVN change for the revision : 45607
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/simwe/simlib/erod.c
The system don't find class, method and function
 in this file during analysis!
          File :/raster/simwe/simlib/waterglobs.h
          Class
Point(Begins at: 78, Ends at:82)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
flags(Begins at: 61, Ends at:64)
          Class
options(Begins at: 50, Ends at:57)
          Class
seed(Begins at: 68, Ends at:71)
Clone analysis:
This file does not contain cloned functions
          File :/raster/simwe/simlib/hydro.c
          Function
main_loop(Begins at: 133, Ends at:479)
              |          New Metrics           |Old Metrics|
Complexity:   |      38 |   *** |      MONSTER |        38 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      32 |     * |      WARNING |        32 |
LOC:          |     347 |   *** |      MONSTER |       347 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/raster/simwe/simlib/output.c
          Function
output_data(Begins at: 72, Ends at:593)
Complexity:   |      72 |   *** |      MONSTER |        72 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     174 |   *** |      MONSTER |       174 |
LOC:          |     522 |   *** |      MONSTER |       522 |
output_walker_as_vector(Begins at: 21, Ends at:68)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      48 |       |           OK |        48 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :/raster/simwe/r.sim.sediment/main.c
          Function
main(Begins at: 101, Ends at:400)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      94 |   *** |      MONSTER |        94 |
LOC:          |     300 |   *** |      MONSTER |       300 |
Clone analysis:
          File :/raster/simwe/r.sim.water/main.c
          Function
main(Begins at: 108, Ends at:509)
Complexity:   |      19 |     * |      WARNING |        19 |
CalledNBR:    |     112 |   *** |      MONSTER |       112 |
LOC:          |     402 |   *** |      MONSTER |       402 |
Clone analysis:
          File :/raster/simwe/simlib/input.c
          Function
input_data(Begins at: 27, Ends at:416)
Complexity:   |      70 |   *** |      MONSTER |        70 |
CalledNBR:    |      74 |   *** |      MONSTER |        74 |
LOC:          |     390 |   *** |      MONSTER |       390 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sun Mar 13 13:17:03 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
