[GRASS-QA] GRASS QA: martinl |main.c parse.c main.c main.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sun Mar 13 15:22:19 EDT 2011
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 45656
ANALYSIS
your changes to files/class/methods/functions :
          File :/general/g.region/main.c
The system don't find class, method and function
 in this file during analysis!
          File :/vector/v.info/parse.c
          File :/vector/v.info/main.c
          File :/vector/v.kernel/main.c
          File :/lib/vector/Vlib/find.c
          File :/vector/v.to.3d/trans3.c
          File :/vector/v.generalize/misc.c
          File :/vector/v.hull/hull.c
          File :/lib/lidar/zones.c
          Function
P_zero_dim(Begins at: 9, Ends at:17)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/vector/v.split/main.c
          File :/vector/v.to.db/lines.c
          File :/vector/v.build/main.c
          File :/lib/vector/Vlib/ascii.c
          File :/vector/v.parallel/main.c
          File :/vector/v.net/args.c
          File :/lib/vector/Vlib/geos.c
          File :/vector/v.buffer/main.c
          Class
buf_contours(Begins at: 72, Ends at:77)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
Clone analysis:
          File :/vector/v.select/overlap.c
____________________________________________
Threshold grass key metrics values at Sun Mar 13 15:22:09 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
