[GRASS-QA] GRASS QA: hamish |points.c draw.c grid.c main.c ...| no clones | 4 monsters |6 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Mar 23 17:52:52 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 45729
ANALYSIS
your changes to files/class/methods/functions :
          File :/display/d.barb/points.c
          Function
count_pts_in_region(Begins at: 109, Ends at:150)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      42 |       |           OK |        42 |
Conclusion:   | this function is a            OK           |
metrics are OK
do_barb_points(Begins at: 10, Ends at:106)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      25 |     * |      WARNING |        25 |
LOC:          |      97 |     * |      WARNING |        97 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
fill_arrays(Begins at: 155, Ends at:269)
Complexity:   |      19 |     * |      WARNING |        19 |
CalledNBR:    |      35 |     * |      WARNING |        35 |
LOC:          |     115 |     * |      WARNING |       115 |
max_magnitude(Begins at: 273, Ends at:282)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/display/d.barb/draw.c
          Function
arrow_360(Begins at: 50, Ends at:55)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a  BABY-MONSTER           |
arrow_mag(Begins at: 60, Ends at:102)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      43 |       |           OK |        43 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
draw_barb(Begins at: 15, Ends at:47)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      10 |       |           OK |        10 |
LOC:          |      33 |       |           OK |        33 |
draw_circle(Begins at: 166, Ends at:208)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
draw_feather(Begins at: 214, Ends at:361)
Complexity:   |      16 |     * |      WARNING |        16 |
CalledNBR:    |     163 |   *** |      MONSTER |       163 |
LOC:          |     148 |    ** | BABY-MONSTER |       148 |
mark_the_spot(Begins at: 124, Ends at:160)
LOC:          |      37 |       |           OK |        37 |
metrics are OK
unknown_(Begins at: 107, Ends at:121)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
Clone analysis:
          File :/display/d.barb/grid.c
          Function
do_barb_grid(Begins at: 10, Ends at:165)
Complexity:   |      24 |    ** | BABY-MONSTER |        24 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      43 |    ** | BABY-MONSTER |        43 |
LOC:          |     156 |    ** | BABY-MONSTER |       156 |
Clone analysis:
          File :/display/d.barb/main.c
          Function
main(Begins at: 26, Ends at:253)
CalledNBR:    |      83 |   *** |      MONSTER |        83 |
LOC:          |     228 |   *** |      MONSTER |       228 |
Clone analysis:
          File :/display/d.barb/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/display/d.barb/legend.c
          Function
do_legend(Begins at: 8, Ends at:65)
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      58 |       |           OK |        58 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Mar 23 17:52:38 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
