[GRASS-QA] GRASS QA: hamish |points.c draw.c | no clones | 3 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Mar 24 17:45:02 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 45745
ANALYSIS
your changes to files/class/methods/functions :
          File :/display/d.barb/points.c
          Function
fill_arrays(Begins at: 155, Ends at:270)
              |          New Metrics           |Old Metrics|
Complexity:   |      19 |     * |      WARNING |        19 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      36 |     * |      WARNING |        36 |
LOC:          |     116 |     * |      WARNING |       116 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
do_barb_points(Begins at: 10, Ends at:106)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      26 |     * |      WARNING |        26 |
LOC:          |      97 |     * |      WARNING |        97 |
Clone analysis:
This file does not contain cloned functions
          File :/display/d.barb/draw.c
          Function
draw_feather(Begins at: 206, Ends at:376)
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |     187 |   *** |      MONSTER |       187 |
LOC:          |     171 |    ** | BABY-MONSTER |       171 |
draw_circle(Begins at: 166, Ends at:200)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      35 |       |           OK |        35 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Mar 24 17:44:51 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
