[GRASS-QA] GRASS QA: hamish |points.c draw.c grid.c main.c ...| no clones | 3 monsters |5 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Mar 26 07:15:53 EDT 2011
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 45758
ANALYSIS
your changes to files/class/methods/functions :
          File :/display/d.barb/points.c
          Function
do_barb_points(Begins at: 10, Ends at:109)
              |          New Metrics           |Old Metrics|
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      28 |     * |      WARNING |        28 |
LOC:          |     100 |     * |      WARNING |       100 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :/display/d.barb/draw.c
          Function
arrow_360(Begins at: 49, Ends at:55)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a  BABY-MONSTER           |
draw_barb(Begins at: 14, Ends at:46)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      33 |       |           OK |        33 |
unknown_(Begins at: 108, Ends at:120)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
arrow_mag(Begins at: 60, Ends at:104)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      45 |       |           OK |        45 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
draw_feather(Begins at: 205, Ends at:594)
Complexity:   |      43 |   *** |      MONSTER |        43 |
CalledNBR:    |     492 |   *** |      MONSTER |       492 |
LOC:          |     390 |   *** |      MONSTER |       390 |
Clone analysis:
          File :/display/d.barb/grid.c
          Function
do_barb_grid(Begins at: 10, Ends at:168)
Complexity:   |      24 |    ** | BABY-MONSTER |        24 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      45 |    ** | BABY-MONSTER |        45 |
LOC:          |     159 |    ** | BABY-MONSTER |       159 |
Clone analysis:
          File :/display/d.barb/main.c
          Function
main(Begins at: 26, Ends at:254)
Complexity:   |      19 |     * |      WARNING |        19 |
CalledNBR:    |      85 |   *** |      MONSTER |        85 |
LOC:          |     229 |   *** |      MONSTER |       229 |
Clone analysis:
          File :/display/d.barb/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/display/d.barb/legend.c
          Function
do_legend(Begins at: 8, Ends at:74)
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      67 |     * |      WARNING |        67 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Mar 26 07:15:49 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        64 |       145 |       226 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
