[STATSGRASS] grass, gstat, and 3d maps
Javier andresjavier.garcia at wanadoo.es
Mon Apr 22 08:35:07 EDT 2002
Hello all;
When I try to use a site list with 3 dimensions, (and a couple of attributes also), with gstat, the file can't be read.
I've tried to use it in the same way that I use the usual 2d maps of Grass with Gstat. I mean that in the first line of the
command file to use as input for Gstat, I don't specify the row containing the data.
I've tried to specify the columns in several ways with no success.
Is it possible to read these maps directly from grass? If so, how do I specify the z column and the column of data of
concern?
Thank you in advance for any help
Javier Garcia
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20020422/fcf72528/attachment.html
More information about the grass-stats mailing list
