[STATSGRASS] writing grass format from R
Roger Bivand Roger.Bivand at nhh.no
Tue Jun 10 13:51:32 EDT 2003
I would think that the output of gstat in R could be moved back to the
GRASS database using the R/GRASS interface, and then accessed from
Mapserver. I don't have access to a computer with the necessary software
now, but will post a suggestion on Thursday morning - the R/GRASS
interface expects a vector ordered in the way that GRASS rasters are
stored.
Roger
> Christian,
> gstat nowadays has two reincarnations: (i) as stand-alone program, in
> which case it can read and write grass data and maps; (ii) as an R
> package (or S-PLUS library), in which case it operates directly in the R
> environment. It cannot do both at the same time. However,
> there is a R-GRASS interface. AFAIK it does not write graph results to
> GRASS, but it can write R data back to grass. GRASS can make
> the graphs, I'd say.
> I'm not familiar to Mapserver.
> Edzer
> Christian Blumer wrote:
>> Dear list,
>>  I would like to know if there is a way to write a R graph results
>> into Grass image format?
>> Or should I use Gstat?
>> The idea behind is to produce geostatistical modeled images that are
>> then made accessible through internet through Mapserver.
>> Christian
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
NHH, Breiviksveien 40, N-5045 Bergen, Norway
More information about the grass-stats mailing list
