[STATSGRASS] gstat problem on Linux
Edzer J. Pebesma e.pebesma at geog.uu.nl
Thu Mar 4 09:21:16 EST 2004
Hi Thomas, I remember trying to look at your data about a
month ago, but it required more GRASS expertise than I could manage.
So my main question is: can you make a small, reproducable example
that I could investigate (on linux only)?
Do both your GRASS installations have the same version?
Edzer
Thomas Adams wrote:
> I have been using GSTAT with GRASS successfully on a Mac OS X system
> with no problems. When I move the **IDENTICAL** files to a Linux
> system (RedHat Linux 7.3) the GSTAT variogram code works fine, but
> when I attempt to generate a predicted map using ordinary kriging I
> get a singled valued map, which is completely different from the
> results with the same data on my Mac OS X system.
> I have attached 2 gif files that show the difference; the
> "precip.200301_pr.map.gif" is generated on Linux (the one that is bad
> - the single value everywhere is 1.528851), the "2003.pr.gif" was
> generated on Mac OS X, which is correct.
> gstat kriging output:
> GRASS:/grass/data > gstat gstat.krige.200301.precip
> gstat: Linux version 2.4.3 (04 July 2003)
> Copyright (C) 1992, 2003 Edzer J. Pebesma
> using Marsaglia's random number generator
> name|sta.precip.200301.15k
> desc|s.in.ascii sites=sta.precip.200301.15k
> input=sta.precip.200301.grass fs='|'
> GRASS site list sta.precip.200301.15k: 0 cat, 2 dim, 0 str, 1 dbl.
> data(precip.200301): gstat/grass: 414 sites read successfully.
> sta.precip.200301.15k     (GRASS site list)
> attribute:             col[1]     [x:] x_1        : [
> 193192,1.74381e+06]
> n:                        414     [y:] y_2        : [
> 992152,2.21716e+06]
> sample mean:          1.64865     sample std.:          0.87102
> [using ordinary kriging]
> ncols 305
> nrows 242
> initializing maps ..
> 84% done
> CREATING SUPPORT FILES FOR precip.200301_pr.map
> CREATING SUPPORT FILES FOR precip.200301_var.map
> 100% done
> One twist is that during the gstat build I get the following:
> gcc -c -O  -DHAVE_CONFIG_H hsehldr.c
> ar ru meschach.a lufactor.o chfactor.o qrfactor.o solve.o norm.o
> hsehldr.o
> ranlib meschach.a
> make[1]: warning:  Clock skew detected.  Your build may be incomplete.
> make[1]: Leaving directory `/grass/gstat-2.4.3/meschach'
> cp meschach/meschach.a lib/libmeschach.a
> (cd src; make)
> make[1]: Entering directory `/grass/gstat-2.4.3/src'
> I have found on the internet that this type of warning can occur with
> older versions of Gnu make, but I am using version 3.79.1.
> Any and all ideas are welcomed!
> Regards,
> Tom
Skipped content of type multipart/related
More information about the grass-stats mailing list
