[STATSGRASS] Using GRASS/R interface with an xy location
Steven T.Stoddard sstoddar at life.uiuc.edu
Tue Feb 8 11:40:54 EST 2005
I am using GRASS 5.7 and R 2.0 for OS X.  I have a simple xy location I
am doing some theoretical work with and would like to import maps into
R using the interface in order to do analyses.  Yet when I attempt to
do this, I get the following error:
 >G<-gmeta()
Error in gmeta() : region for current mapset is invalid
line 11: <top:        100>
run "g.region"
I traced the problem to the compiled C program that is called from the
gmeta R function (i.e. > .C("gmeta") gives me the same error). I
haven't been able to locate the source code on my volume.
If I use gmeta(interp = TRUE) there is no problem, until I want to
actually try and import data from my locations.
Any help is appreciated.
Steve
Steven T. Stoddard
Program in Ecology, Evolution and Conservation Biology
University of Illinois at Urbana-Champaign
(217) 333-2235
302 Shelford Vivarium
606 E. Healy Ave
Champaign, IL  61820
http://www.life.uiuc.edu/~sstoddar
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20050208/910d3d7e/attachment.bin
More information about the grass-stats mailing list
