[STATSGRASS] Using GRASS/R interface with an xy location & reverse(G) error
Roger Bivand Roger.Bivand at nhh.no
Tue Feb 8 12:18:34 EST 2005
On Tue, 8 Feb 2005, Steven T.Stoddard wrote:
> Ok.  The work-around I can grow accustomed to, or I might fall back on
> GRASS5.4 if that works.
> I wonder if another problem that cropped up is somehow related to the
> first.  Using interp=TRUE I managed to import a raster map to R.  But
> when trying to plot it, I get the following:
>  > plot(G,tt$rb1)
> Error in reverse(G) : cannot allocate vector of length 1086556160
What does summary(G) say? It sounds as though the numbers of rows and/or
columns have the wrong values.
Over 1G cells is a bit extreme?
Roger
> Thanks for the help,
> Steve
> Steven T. Stoddard
> Program in Ecology, Evolution and Conservation Biology
> University of Illinois at Urbana-Champaign
> (217) 333-2235
> 302 Shelford Vivarium
> 606 E. Healy Ave
> Champaign, IL  61820
> http://www.life.uiuc.edu/~sstoddar
> >> I am using GRASS 5.7 and R 2.0 for OS X.  I have a simple xy location
> >> I
> >> am doing some theoretical work with and would like to import maps into
> >> R using the interface in order to do analyses.  Yet when I attempt to
> >> do this, I get the following error:
> >>> G<-gmeta()
> >> Error in gmeta() : region for current mapset is invalid
> >> line 11: <top:        100>
> >> run "g.region"
> >> I traced the problem to the compiled C program that is called from the
> >> gmeta R function (i.e. > .C("gmeta") gives me the same error). I
> >> haven't been able to locate the source code on my volume.
> >> If I use gmeta(interp = TRUE) there is no problem, until I want to
> >> actually try and import data from my locations.
> > The current fix for 5.7 and 6.0.0beta is to use interp=TRUE. The cause
> > of
> > the problem seems to be the use of the 3D WINDOW, which the older code
> > in
> > the R-GRASS interface doesn't yet honour. I'm not at all sure what will
> > happen if your x,y locations are sites; the interface knows about
> > old-style sites, not vector sites. You may be obliged to use
> > system("") to
> > issue GRASS 5.7 commands to write out an ASCII file to read into R with
> > read.table().
> > Roger
> >> Any help is appreciated.
> >> Steve
> >> Steven T. Stoddard
> >> (217) 333-2235
> >> 606 E. Healy Ave
> >> Champaign, IL  61820
> > Roger Bivand
> > Economic Geography Section, Department of Economics, Norwegian School
> > of
> > Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
> > Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
> > e-mail: Roger.Bivand at nhh.no
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
More information about the grass-stats mailing list
