[STATSGRASS] isolines
Tim Michelsen timmichelsen at gmx-topmail.de
Sun Feb 27 18:18:00 EST 2005
> GRASS has limited support for TINs, you would have to extract values at
> the nodes (v.in.ogr? -> vector points), interpolate to a raster map
> using splines (v.surf.rst), then create vector isolines with r.contour.
Do you know any R package that might be able to do the job?
Thanks,
Tim
More information about the grass-stats mailing list
