[STATSGRASS] problems assesing mapsets
Roger Bivand Roger.Bivand at nhh.no
Thu Jan 13 06:15:21 EST 2005
On 13 Jan 2005, Marta Benito wrote:
> Hi,
> I am having problems using the GRASS library in R.
> I think I am doing something wrong when using gmeta but I don't know
> exactly, the problem began when I've done update of packages in R and
> GRASS.
> GRASS 5.7.cvs:~/grassdata/espanya_modelo_devel > R
> > library(GRASS)
> GRASS environment variables in: /tmp/grass6-marta-8901/gisrc
>  G<-gmeta()
> Error in gmeta() : region for current mapset MAPSET
> run "g.region"
You seem to be using GRASS 5.7 or 6.0beta1, is that correct?
Please try G <- gmeta(interp=TRUE), and post the result (str(G)) - this
may be a WIND3 WINDOW not being recognised by the 5.0 version of the GRASS
function used when run with interp=FALSE.
Roger
> I have already run g.region in GRASS, and also after the error.
> Thank you in advance
> Marta
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
