[STATSGRASS] GSTAT 2.4.5 compile problem with GRASS 6
Edzer J. Pebesma e.pebesma at geog.uu.nl
Mon Jun 20 12:36:50 EDT 2005
Could you please give us the ./configure command you gave?
Could you try to give the make command in a grass6 session?
I have had success with this in the past. Recently, I didn't
succeed with this anymore (for reasons unclear to me; must
have to do with my memory because I didn't change the grass
installation inbetween!), but last week I managed with
./configure --with-grass6=PATH
Please report back which ones did, or didn't work.
Best regards,
Edzer
S. Koukoulas wrote:
> I get an error when I am trying to compile GSTAT 2.4.5 with the grass
> option. Any solutions?
> Many thanks in advance
> Sotiris
> gcc -o gstat block.o data.o direct.o fig.o fit.o getest.o gls.o glvars.o
> gstat.o lex.o lm.o map2fig.o map2gd.o mapio.o maputils.o msim.o nsear
> ch.o ossfim.o palet.o parse.o plot.o polygon.o pqueue.o predict.o
> random.o read.o reml.o report.o sample.o select.o sem.o sem_main.o sim.o
> sta
> t.o ui.o userio.o utils.o vario.o vario_fn.o vario_io.o writecmd.o
> xvalid.o  -L../lib  -lmeschach -lnetcdf  -lncurses -lgd -lpng -lz -lgdal -L
> /usr/local/grass-6.0.0beta2/lib -lgrass_gis -lgrass_datetime
> -lgrass_sites -lz -lm
> /usr/lib/gcc-lib/i586-suse-linux/3.3.4/../../../../i586-suse-linux/bin/ld:
> warning: libgrass_dbmiclient.so, needed by /usr/local/grass-6.0.0be
> ta2/lib/libgrass_sites.so, not found (try using -rpath or -rpath-link)
> warning: libgrass_dbmibase.so, needed by /usr/local/grass-6.0.0beta
> warning: libgrass_vect.so, needed by /usr/local/grass-6.0.0beta2/li
> warning: libgrass_dig2.so, needed by /usr/local/grass-6.0.0beta2/li
> warning: libgrass_dgl.so, needed by /usr/local/grass-6.0.0beta2/lib
> warning: libgrass_rtree.so, needed by /usr/local/grass-6.0.0beta2/l
> warning: libgrass_linkm.so, needed by /usr/local/grass-6.0.0beta2/l
> /usr/local/grass-6.0.0beta2/lib/libgrass_sites.so: undefined reference
> to `Vect_reset_line'
> to `db_get_num_rows'
> to `Vect_set_open_level'
> to `Vect_get_field'
> to `Vect_is_3d'
> to `Vect_set_map_name'
> to `db_init_string'
> to `db_get_column_sqltype'
> to `Vect_open_old'
> to `db_open_select_cursor'
> to `Vect_new_cats_struct'
> to `Vect_get_name'
> to `db_start_driver_open_database'
> to `Vect_get_date'
> to `Vect_write_line'
> to `Vect_close'
> to `db_get_value_double'
> to `db_sqltype_to_Ctype'
> to `db_close_database_shutdown_driver'
> to `db_get_value_string'
> to `db_get_column_value'
> to `db_append_string'
> to `Vect_cat_get'
> to `Vect_read_next_line'
> to `db_get_column_name'
> to `db_get_value_int'
> to `Vect_append_point'
> to `Vect_set_date'
> to `Vect_set_comment'
> to `db_get_table_column'
> to `Vect_cat_set'
> to `db_fetch'
> to `db_get_table_number_of_columns'
> to `db_set_string'
> to `db_get_cursor_table'
> to `Vect_reset_cats'
> to `Vect_get_comment'
> to `Vect_new_line_struct'
> to `Vect_build'
> to `Vect_open_new'
> collect2: ld returned 1 exit status
> make[1]: *** [gstat] Error 1
> make[1]: Leaving directory `/local/phome/Installs/gstat-2.4.5/src'
> make: *** [src/gstat] Error 2
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
