[STATSGRASS] GSTAT 2.4.3 compile problem with GRASS 5.4
Edzer J. Pebesma e.pebesma at geog.uu.nl
Wed Mar 16 02:36:16 EST 2005
Roger Bivand wrote:
>On Tue, 15 Mar 2005, Edzer J. Pebesma wrote:
>>Roger Bivand wrote:
>>>On Tue, 15 Mar 2005, Thomas Adams wrote:
>>>>I am having GSTAT 2.4.3 compile problems with GRASS 5.4. When
>>>>configuring gstat for compilation I use:
>>>>./configure --with-grass=/awips/rep/lx/local_apps/grass-build
>>>>The GRASS 5.4 lib & include directories are located in
>>>>/awips/rep/lx/local_apps/grass-build, but I notice when gstat is being
>>>>configured for compilation, I get:
>>>>checking for G_gisinit in -lgrass_gis... no
>>>>checking for G_gisinit in -lgis... no
>>>Edzer: is this related to 5.4.0 going just shared? That only the *.so are
>>>in build/dist*/lib? On grass5, Glynn asked on Sunday:
>>>"I think that the point is that binary distributions should always
>>>include the libraries regardless of whether they are shared or static.
>>>IIRC, we currently only include the libraries if they are shared
>>>libraries.
>>>From a packaging (RPM etc) perspective, static libraries would
>>>normally go into a separate -devel package, along with the headers,
>>>while shared libraries would go into the main package."
>>>The configure seems to fail because it is looking for libgis.a or
>>>libgrass_gis.a at:
>>> AC_CHECK_LIB(grass_gis, G_gisinit, GISLIB="-lgrass_gis -lgrass_datetime",
>>>  AC_CHECK_LIB(gis, G_gisinit, GISLIB="-lgis -ldatetime"))
>>>isn't it? Should it see a *.so as an *.a, they are different animals,
>>>aren't they?
>>No. They're different, but the .a are not required. gstat 2.4.4
>>links to grass-6.0.0beta1, which contains only .so in the lib dir;
>>I tried the 2.4.3 (targeted at grass 5.x) and the configure
>>worked on the grass6 machine, it finds the .so libraries. Then it
>>doesn't compile, for obvious reasons.
>>Thomas, could you double-check the directory names?
>It could be that grass-build is actually grass-build/dist.*
>I've tried without success with 2.4.3 on 5.4.0 on my machine, both going
>for the grass-build/dist* and the install directory grass54/ which has lib
>in it. I've got a working 5.4.0 (I think).
Roger, I'm sorry, you were right, but it can be solved easily.
The issue is that dynamic libraries are only linked against
automatically if they are in a "trusted"
directory, which are on my machine listed in /etc/ld.so.conf
(run ldconfig after you modify it; read man ldconfig).
So if you want to run gstat with grass support any way,
you'd have to add the /usr/local/grassxxx/lib directory
there, and run ldconfig.
If you _only_ want to run gstat within grass sessions (which
makes sense, because only then it should know where to
look for data!) you should run
./configure --with-grass=/path/to/grass
within the grass shell, because grass sets the
environment variable to your active grass version lib dir:
LD_LIBRARY_PATH=/usr/local/grass-6.0.0beta1/lib
which has the same effect, but only for the session in
which this env var is set.
In that case, when gstat is ran outside a grass session
you'll get something like
gstat: error while loading shared libraries: libgrass_gis.so: cannot
open shared object file: No such file or directory
because gstat (actually the runtime linker) doesn't know
where to find the .so files. I figure you get this too when
running grass binaries outside a grass shell.
Best regards,
Edzer
More information about the grass-stats mailing list
