[STATSGRASS] Re: Connecting to databases on Windows using R
Teague O'Mara Teague.Omara at asu.edu
Thu Mar 17 16:11:16 EST 2005
Craig and Markus:
Just trying it I get the same complaint for both:
trying URL `http://www.bioconductor.org/repository/devel/package/Source//PACKAGES'
Error in download.file(url = paste(contriburl, "PACKAGES", sep = "/"),  :
        cannot open URL
In addition: Warning message:
cannot open: HTTP status was `404 Not Found'
Apparently the page has moved, or the packages have been taken off?
Also, Rdbi will load, but I get the following message:
Loading required package: Rdbi
[1] TRUE
Warning message:
package 'Rdbi' was built under R version 2.1.0
I searched around for a new version of R, but it seems that 2.0.1 is the latest
version.  Or is 2.1 new source code for Linux?
Teague
Quoting Craig Aumann <caumann at ualberta.ca>:
> Well I'm curious to know what R on Windows actually does with the
> following commands:
install.packages(contriburl="http://www.bioconductor.org/repository/devel/package/Source/","Rdbi")
install.packages(contriburl="http://www.bioconductor.org/repository/devel/package/Source/","RdbiPgSQL")
> Does it successully install the packages, or complain loudly?
> On Thu, 2005-03-17 at 13:30, Markus Neteler wrote:
> > Hi
> > (for me) it's strange that Rdbi doesn't appear on CRAN but
> > I was already notified once not to discuss Rdbi questions on
> > the R Mailing lists... (so better to ask here :-)
> > Anyway, I have compiled some usage instructions here:
> >  http://grass.itc.it/statsgrass/r_and_dbms.html
> > which should be more or less still valid.
> > Maybe a bit helpful, also comparing speed of Rdbi and RODBC.
> > However, it doesn't cover MS-Win installation...
> > Best
> >  Markus
> > On Thu, Mar 17, 2005 at 11:33:02AM -0700, Craig Aumann wrote:
> > > See Teague's question below.  As a linux person, I don't know the
> answer
> > > to this so am forward this message to the list.
> > > Having looked also at  http://www.bioconductor.org/ - which links
> off of
> > > the main R web page, I see a Windows version of Rdbi (click "What
> is
> > > Bioconductor"  and scroll down till you find the heading:
> "Database
> > > Interaction").  I'm seeing a RDBI for Windows, but no windows
> version of
> > > RdbiPgsql which is a problem!
> > > Have you tried sending a message to the R-Help list about this - how
> do
> > > windows users access PGSQL databases from R?  (R website ->
> mailing
> > > lists.)
> > > On the CRAN site, just searching databases, I saw the following:
> > > DBI, RMySQL, RODBC, ROracle. Not sure if windows versions exist for
> any
> > > of these.
> > > Also have a look at the links in
> > > http://cran.r-project.org/doc/manuals/R-data.html .
> > > Afraid that's all I know about attaching to Databases on Windows -
> which
> > > ain't much I'm afraid.
> > > Cheers!
> > > Craig
> > > On Thu, 2005-03-17 at 10:40, Teague O'Mara wrote:
> > > > Hi Craig.  I came back across this email from awhile ago.  I'm
> attempting to
> > > > look at cluster of points in GRASS and have been using the script
> that Michael
> > > > Barton wrote, but I'd like to look at a few other things and it
> seems that using
> > > > R and my GRASS data will be much easier. I have been using R for
> basic
> > > > statistics, but am far from being fluent with it.  If you have a
> moment, can you
> > > > help me out with some R issues?  I'm using an XP machine with R
> 2.0.1.
> > > > I'm having a problem downloading and installing Rdbi and
> RdbiPgSQL.  I can't
> > > > find these two sets, or any SQL interface that will download from
> CRAN.  I was
> > > > able to download these directly from sourcforge (tar.gz format),
> but I'm not
> > > > sure what to do with them now.  Is it an issue with this version
> of R?
> > > > Thanks for any help you can offer.
> > > > Cheers--
> > > > Teague
> > > > Teague O'Mara
> > > > Department of Anthropology
> > > > Arizona State University
> > > > Box 872402
> > > > Tempe, AZ 85287-2402
> > > > 480.965.6213
> > > > > In glancing at your script, I wondered why you didn't just
> import the
> > > > > stuff into a statistical package like R and then use all the
> > > > > clustering
> > > > > routines it has.    See www.r-project.org
> > > > > ## Key commands in R are:
> > > > > ## Load the packages to access the database, in particular the
> PgSQL
> > > > > database
> > > > > require(Rdbi)
> > > > > require(RdbiPgSQL)
> > > > > ## Load some clustering routines
> > > > > require(cluster)
> > > > > require(mclust)
> > > > > ### Connect to the database and read in a points data set
> "jogis"
> > > > > ## and read in the dataset "wells_att".
> > > > > conn <- dbConnect(PgSQL(), dbname="jogis", user="caumann")
> > > > > wells <- dbReadTable(conn, "wells_att")
> > > > > dbDisconnect(conn)
> > > > > ## Now you can apply any clustering or kernel smoothing
> technique you
> > > > > want to the dataset.
> > > > > If this is of any help, let me know and I can provide more
> details.
> > > > > Cheers!
> > > > > Craig
> > > _______________________________________________
> > > statsgrass mailing list
> > > statsgrass at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/statsgrass
Teague O'Mara
Box 872402
480.965.6213
More information about the grass-stats mailing list
