[STATSGRASS] isolines [solved]
Poizot Emmanuel poizot at cnam.fr
Fri Mar 25 03:10:09 EST 2005
Tim Michelsen wrote:
>>On Mon, 28 Feb 2005, Tim Michelsen wrote:
>>>>GRASS has limited support for TINs, you would have to extract values at
>>>>the nodes (v.in.ogr? -> vector points), interpolate to a raster map
>>>>using splines (v.surf.rst), then create vector isolines with r.contour.
>>>Do you know any R package that might be able to do the job?
>>No direct route from points to contours without interpolation in R. The
>>nearest I can see would be to use GMT's pscontour, inputting an ASCII xyz
>>file, and dumping the contour line output to file.
>Finally I used contour() in R native to achive it.
>But does anyone know how to plot gradient arrows that demonstrate flow
>streams?
>E. g. from the higher valued isoline to the lower valued.
>Thanks and greetings,
>Tim
>_______________________________________________
>statsgrass mailing list
>statsgrass at grass.itc.it
>http://grass.itc.it/mailman/listinfo/statsgrass
you can use arrow.plot from fields package:
arrow.plot(a1, a2, u = NA, v = NA, arrow.ex = 0.05,
          xpd = TRUE, true.angle = FALSE, ...)
Regards
Emmanuel Poizot
More information about the grass-stats mailing list
