[STATSGRASS] gstat limitation?
Roger Bivand Roger.Bivand at nhh.no
Fri Jul 28 07:15:15 EDT 2006
On Thu, 27 Jul 2006, Carlos "Guâno" Grohmann wrote:
> I am running it in R. it get killed in the kriging step. I guess its
> abot system memory.
What does "killed" mean? Specifically, what is the error message? Is it a
malfunction?
If I understand, you have about 300000 data points and want to predict to
about 2.5 million, using a very small maximum distance. I would have
looked at subsetting, if there is no other way round.
Roger
> Carlos
> > > Hello
> > > I was wondering if gstat has any limitation about file size it can
> > > process. I want to resample a DEM of a large area (about 50x50 km, 30m
> > > res.) with kriging, but it get killed.
> > That sounds painful, but it doesn't tell much. Without your verbatim
> > commands, it is difficult to tell - are you running gstat standalone, or
> > in R? At what step in the modelling process does the problem arise?
> > Roger
> > > Carlos
> > Roger Bivand
> > Economic Geography Section, Department of Economics, Norwegian School of
> > Economics and Business Administration, Helleveien 30, N-5045 Bergen,
> > Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
> > e-mail: Roger.Bivand at nhh.no
Roger Bivand
More information about the grass-stats mailing list
