[STATSGRASS] spgrass6 rastget6 bug??
Ulrich Leopold uleopold at science.uva.nl
Thu Mar 23 04:58:02 EST 2006
Dear list,
I am trying to automate some statistics with the help of the latest version of
spgrass6 and rastget6. The problem I encounter is that when I load maps from
within GRASS-6.0.1 with
alzette <- rast.get6(c("surface_alzette_sealed", "precip_obkp"), cat=c(TRUE,
FALSE))
it shows a progress which only counts to 96%. Then this number blocks the next
command in a script. The only way to get around it is to press return on the
command line which I cannot do in the script.
Is this a bug. And if yes. Do you know any work arounds?
Any help appreciated.
Cheers, Ulrich
More information about the grass-stats mailing list
