[STATSGRASS] spgrass6 - conversions "zeros" to N/A?
Jarosław Jasiewicz jarekj at amu.edu.pl
Mon Nov 20 06:42:38 EST 2006
Roger Bivand napisał(a):
> The most recent release of spgrass6 introduced a change in this - the
> underlying r.in.bin and r.out.bin use 0 as NA, and now the value can
> be set or -9999 used as default. If updating doesn't solve the
> problem, please let me know.
> Best wishes,
> Roger
> Roger Bivand, NHH, Helleveien 30, N-5045 Bergen,
> Roger.Bivand at nhh.no
> -----Original Message-----
> From: statsgrass-bounces at grass.itc.it on behalf of Jarek Jasiewicz
> Sent: Sun 19.11.2006 18:40
> To: statsgrass at grass.itc.it
> Subject: [STATSGRASS] spgrass6 - conversions "zeros"  to N/A?
> Hi
> When I transferr map from grass to R with some values = 0 these valuses
> are converted to N/A. I can ommit this converting zeros to small number
> for example 0.0000001, but it is not an solution - for example with
> curvature
> regards
> Jarek
> statsgrass mailing list
> http://grass.itc.it/mailman/listinfo/statsgrass
now works, thanks
Jarek
More information about the grass-stats mailing list
