[STATSGRASS] v.variogram
Tomas Lanczos lanczos at t-zones.sk
Sat Oct 7 20:03:14 EDT 2006
> From: Roger Bivand [mailto:Roger.Bivand at nhh.no]
> This looks as though the modification stops v.out.ogr -e from
> working, and results in no shapefile being written. Could you
> see what happens when you run v.out.ogr -e for your point
> vector data? My guess is that it will fail. It may also fail
Happens this, in fact the export performs:
GRASS_INFO_WARNING(15398,1): OGR can't parse PROJ.4-style parameter string:
GRASS_INFO_WARNING(15398,1):  +proj=krovak +a=6377397.155 +rf=299.1528128
+no_defs +to_meter=1.0000000000
GRASS_INFO_WARNING(15398,1): (OGR Error code was 5)
Exporting 89 points/lines...
89 features written
> with just v.out.ogr, because v.out.ogr tries to write a *.prj
> anyway for shapefiles, and that may just not work following
> the patch. Could you let me know if other OGR drivers do any better?
It's almost the same with the other drivers.
Tomas
> Roger
> > Error in ogrInfo(dsn = dsn, layer = layer) :
> > 	Cannot open file
> > Execution halted"
> > I suppose that this error occures when grass, resp. ogr is
> reading the
> > computed data back. Is it problem with the proj.4 style
> itself (how is
> > written back) or that I am using the patched proj4 (the patch was
> > prepared by Jachym Cepicky - I guess, as the proj4 does not
> handle the
> > krovak projection correctly). Am I right? Do You have any
> idea how to solve this?
> > > Apart from that, the script depends on using xpdf to view
> pdf files,
> > > an you don not have it installed or on your path.
> > Of course :-).
> > Thanks for any suggestion and/or advice in advance
> > Tomas
> > > Roger
> > > > Loading required package: sp
> > > > Loading required package: maptools Loading required package:
> > > > foreign Loading required package: rgdal Geospatial Data
> > > > Abstraction Library extensions to R successfully loaded
> Error in
> > > > validObject(.Object) : invalid class
> > > "GridTopology" object:
> > > > cellsize has incorrect dimension
> > > > Execution halted
> > > > Done/usr/local/grass-6.3.cvs/scripts/v.variogram: line
> 135: xpdf:
> > > > command not found"
> > > > What can I do with it?
> > > > Note: If I tried to do kriging by the R I recognized that
> > > there is no
> > > > krige.G function for spgrass6.
> > > > Thank for any advice in advance.
> > > > Tomas
> > > > p.s: running Grass 6.3 cvs and R 2.3.0 on Ubuntu 6.0.6,
> > > the databaze
> > > > is PostgreSQL 8.1.3
> > > > _______________________________________________
> > > > statsgrass mailing list
> > > > statsgrass at grass.itc.it
> > > > http://grass.itc.it/mailman/listinfo/statsgrass
> > > Roger Bivand
> > > Economic Geography Section, Department of Economics, Norwegian
> > > School of Economics and Business Administration, Helleveien 30,
> > > N-5045 Bergen, Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
> > > e-mail: Roger.Bivand at nhh.no
> Roger Bivand
> Norwegian School of Economics and Business Administration,
> Helleveien 30, N-5045 Bergen, Norway. voice: +47 55 95 93 55;
> fax +47 55 95 95 43
More information about the grass-stats mailing list
