[STATSGRASS] using R and gstat inside a C module
Roger Bivand Roger.Bivand at nhh.no
Mon Oct 23 12:18:30 EDT 2006
On Mon, 23 Oct 2006, G. Allegri wrote:
> I need to use R and gstat functionalities inside a module I'm writing.
Why? What OS/platform? Unless you are doing something very peculiar, you
will waste an inordinate amount of time, where a shell script will get you
there simply and be several orders of magnitude easier to debug. Be aware
that R functions are often best used interactively because user choices
and error conditions do matter.
> To embed R in a C program libRmath should be used.
No, that is just to use the math functions. See Section 8.1 in
http://cran.r-project.org/doc/manuals/R-exts.html
for Unixalikes (building R as a shared library, most likely libR.so).
> First question:
> Is it possible to load gstat package from the R standalone library?
Yes, like any package, but why?
> Second question:
> Is there another way to do it when working inside a GRASS module? The
> question raises because, with regard to spgrass6, there's no way to
> use it from a module (except by making a shell process call from C)...
Well, you can use the GRASS API to populate the appropriate R object
structures in C (see the GRASS5 GRASS package C code).
> am I wrong?
Yes, because you will never (at least for a definition of never being
greater than the number of developer hours taken to write and maintain
gstat and the R/GRASS interface) be able to do this robustly, taking
account of all possible error conditions (identical points passed to gstat
for example), and track changes in the different software environments
(something that works only with GRASS version x.y.z, R version a.b.c,
gstat version d.e.f, sp version g.h.i, etc. There is simply too much being
patched for a welded-hood C solution to be worth the development and
maintenance cost.
By the way, you didn't say what you want to do that needs this level of
automation; if you had, it might be easier to understand your very strange
design choices and resource commitments.
> Thanks,
> Giovanni
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
